hood latch on a 1971 challenger, is it the same as a 70
#660370
04/04/10 01:09 AM
04/04/10 01:09 AM
Posts: 751 Hermiston Oregon
mopar_leaner
Hermiston Oregon
s a 1970 and 71 challenger primary hood latch the same? I have a nice 70, but I dont know if it will work on a 71 challenger. Any ideas?
Re: hood latch on a 1971 challenger, is it the same as a 70
[Re: mopar_leaner]
#660371
04/04/10 01:13 AM
04/04/10 01:13 AM
Posts: 27,485 So Cal
autoxcuda
So Cal
is a 1970 and 71 challenger primary hood latch the same? I have a nice 70, but I dont know if it will work on a 71 challenger. Any ideas?
71 is different with a bent wire-type pull handle.
The 71 grille gets in the way of 70 hood latch.
[Re: mopar_leaner]
#660373
04/04/10 01:39 AM
04/04/10 01:39 AM
autoxcuda
So Cal
any pictures of a 71?
Instead of the 70 latch with the wide lever that's spot welded on, it's got a linkage that pull the latch forward to open it.
The pull tab part is cut off in this picture. And it has a 90 deg piece of metal with a plastic guide screwed into the hood to support the pull tab/handle.
![](http://www.cpwclub.com/images/71ConvRefUnderhood.JPG)
[Re: mopar_leaner]
#660375
04/04/10 11:39 AM
04/04/10 11:39 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
ops, Im talking about the primary latch, sorry
It's different too...
[Re: mopar_leaner]
#660376
04/04/10 04:18 PM
04/04/10 04:18 PM
autoxcuda
So Cal
Ok, like 1WildRT said it's different too.
But why did you delete your post? The question is still revelent to the primary latch.
Mopar Leaner there are others reading these threads and learning from them. So even if your question is answered, please don't delete your post.
