Schubecks on the street? #660116
04/03/10 08:00 PM
04/03/10 08:00 PM
Lincoln NE
440forPOWER Offline OP
super gas
super gas
Lincoln NE
Just curious, is or has anyone used Schubeck lifters for a street motor? I'm planning a bb street build and have an extra set sitting here. If I run enough spring pressure will they live at low rpms? Thanks in advance
Re: Schubecks on the street? [Re: 440forPOWER] #660117
04/03/10 08:07 PM
04/03/10 08:07 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
Drove cross country with them. Keep adding displacement, still using them in 3rd motor
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Schubecks on the street? [Re: 440forPOWER] #660118
04/03/10 10:54 PM
04/03/10 10:54 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
I can only speak for his Roller X lifters.
They are JUNK!!!
Re: Schubecks on the street? [Re: jim sciortino] #660119
04/03/10 11:26 PM
04/03/10 11:26 PM
Lincoln NE
super gas
super gas
Lincoln NE
Yeah these are the flat tappet lifters.
Re: Schubecks on the street? [Re: 440forPOWER] #660120
04/03/10 11:35 PM
04/03/10 11:35 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I'll be blunt... the only set of Schubecks I trust are the ones I've had since 1999. Mine have 6000+ miles of street / strip / dyno use on five different cams w/o any issues. However, something happened w/ their quality control or manufacturing process at some point after I bought mine and they shipped a lot of lifters that simply didn't hold up before going out of business.
If you don't know when the set you have were made and they haven't ever been used, I'd be scared to put 'em in anything.
Re: Schubecks on the street? [Re: BradH] #660121
04/04/10 12:12 PM
04/04/10 12:12 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
My flat tappets came from Schubeck in 2000 & been great. Schubecks are no longer manufactured by Schubeck, I think its now Smith Machine and can be had through FBO. Good service
Re: Schubecks on the street? [Re: oldiron] #660122
04/04/10 12:19 PM
04/04/10 12:19 PM
Aurora Colorado
BELVEDERE67 Offline
mopar addict
BELVEDERE67  Offline
mopar addict
Aurora Colorado
I've had mine on since 2003. That's the year I bought mine. No issues at all. Like has been said above, their quality had been suspect. I do have to keep them adjusted. The ceramics or puck does NOT like float or out of adjustment. Some have had that ceramic disintegrate.....not good. Attend to that detail and you should be fine.
