et street bias ply or Radials #659798
04/03/10 12:30 PM
04/03/10 12:30 PM
Massachusettes
Twisted360 Offline OP
Massachusettes
Running in street class this year for first time. 340 duster. Need some input on m/t et Street bias or radials or goodyear radial ss drag tires. Thanks, mike
Re: et street bias ply or Radials [Re: Twisted360] #659799
04/03/10 12:42 PM
04/03/10 12:42 PM
Good track radials are faster, bad track bias plys are easier to hook up constsitintly
Re: et street bias ply or Radials [Re: Twisted360] #659800
04/03/10 04:03 PM
04/03/10 04:03 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
I just put M/T N-50X15 Indy profile SS tires on my Dart. Ran at T&T last night with disappointing 60' results, but I did not heat them up first. Anybody else running these tires?
This is the land of the free because of the brave
Re: et street bias ply or Radials [Re: rbstroker] #659801
04/03/10 05:01 PM
04/03/10 05:01 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I had those tires back when I was in high school, and I couldnt get them to hook up with a bone stock 318...if your car makes any power, those tires are worthless, even though they look pretty nostalgic!
Re: et street bias ply or Radials [Re: joshking440] #659802
04/03/10 05:55 PM
04/03/10 05:55 PM
Hinterland SE Qld Aust
SG duster Offline
SG duster  Offline
on my 12 sec car Im currently using M&H racemaster G60x15s they are a 26" tyre with 8" of tread face, they seem to be good so far
Re: et street bias ply or Radials [Re: SG duster] #659803
04/03/10 06:22 PM
04/03/10 06:22 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I may try the nitto drag radial, they last a lot longer than the others, but from what i've read not quite as much bite on the track.
Re: et street bias ply or Radials [Re: ademon] #659804
04/03/10 08:09 PM
04/03/10 08:09 PM
Alliance, Ohio
V
Valiant_Showoff Offline
V
Alliance, Ohio
The M/T Street (bias) are more forgiving of a poorly prepared track. The radials are a couple hundreths faster, but more susceptible to poor tracks.
If you street drive it a lot and might get caught in the rain, stick with the radials. Big difference in driveability.
I've run both on my 11 second Valiant and like the radials much better because of how it drives on the street. I only 60' in the 1.61-1.63 range so I don't need a ton of tire. Current tires are 255-R60/15's M/T Radials which are about 27" tall and 8" wide.
Re: et street bias ply or Radials [Re: Twisted360] #659805
04/04/10 02:21 AM
04/04/10 02:21 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I ran the M/T street ET bias-ply tires, and then switched to the M/T Street ET Radials. The Radials seem stickier and for the limited street driving I do, they handle better, but the radials look like they are wearing out faster than the Bias Ply tires.
I have only run at Bandimere and MATS, and the tracks are usually prepped good, so I can't say if one performs better than the other by the way the track is preped. Anyhow, I'm happy with the radials and would buy another set then they wear out.
Re: et street bias ply or Radials [Re: 451Mopar] #659806
04/04/10 01:43 PM
04/04/10 01:43 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Is there a difference between the M/T street ET's and the M/T Sportsman pros?
Re: et street bias ply or Radials [Re: rbstroker] #659807
04/04/10 01:47 PM
04/04/10 01:47 PM
The ET streets are stickier than the pros and the pros are full tread unlike the streets.
Re: et street bias ply or Radials [Re: Twisted360] #659808
04/04/10 04:38 PM
04/04/10 04:38 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I ran the et streets and they were inconsistent on my dart however, the hoosier qtp`s rock. Worth a try.
Re: et street bias ply or Radials [Re: Thumperdart] #659809
04/04/10 05:25 PM
04/04/10 05:25 PM
Massachusettes
Massachusettes
thanks guys great input. Do you need to run tubes with the et streets or the qtp hoosiers?
Re: et street bias ply or Radials [Re: Thumperdart] #659810
04/04/10 06:42 PM
04/04/10 06:42 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Thumperdart.............what size QTP are you running?
Re: et street bias ply or Radials [Re: Twisted360] #659811
04/04/10 10:41 PM
04/04/10 10:41 PM
Yes but some guys don't.
