70 Challenger 440 6-pk Valve Covers #65927
05/29/08 09:23 PM
05/29/08 09:23 PM
Anonymous OP
Anonymous OP
Can anyone post a picture of the correct valve covers? What I currently have for the driver side has two "U-tabs" (single wire tabs),one on the top side toward the rear, and one near the solenoid bracket on the inside. However, from the pictures I've seen, these tabs don't appear on the driver's side, and all the plug wires are routed toward the front. I also have the boot shield for the no. 7 plug, so it would make sense if there were no tabs on the driver side valve cover.
Also, has anyone used "Plastic Dip" to restore to extensions on the valve cover tabs that are supposed to be there? If so, did it work?
Re: 70 Challenger 440 6-pk Valve Covers #65928
05/29/08 09:32 PM
05/29/08 09:32 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
here's a set I did for a friend - dipped the tabs in a plastic/rubber compound I picked up at Home Depot - forgot the name - good for a driver I think
Re: 70 Challenger 440 6-pk Valve Covers #65929
05/29/08 09:34 PM
05/29/08 09:34 PM
Anonymous OP
Anonymous OP
I did all kinds of research when I bead blasted these, and I am very (99.99%) confident they are correct for 70 and 71 6 pack/barrel cars. I looked at dozens of photos, know what I pulled them off of, and know they were original to that car. Part #'s in the Chrysler parts cat. 2946057 and 2946063. I can take more pictures if you like.
Re: 70 Challenger 440 6-pk Valve Covers #65930
05/29/08 10:09 PM
05/29/08 10:09 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Nice pics.. Here they are with color. What is the wire bracket for on the pcv cover ? The wires are routed underneath on the left bank ? ps. I know the rear #7 wire loom bracket is tightened up wrong.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: 70 Challenger 440 6-pk Valve Covers #65931
05/29/08 11:27 PM
05/29/08 11:27 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
Then there's always that .01% that says you're wrong. 440+6's never had the #7 wire routed over the driver's side valve cover. Sorry.
CHECK OUT MY NEW WEB SITE !
Re: 70 Challenger 440 6-pk Valve Covers [Re: anlauto] #65932
05/29/08 11:42 PM
05/29/08 11:42 PM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
My '70 440 4bbl has those same valve covers, the ones with the wire tab on driver's PCV cover.
It seems the 440-6 didn't route the #7 wire, so what B/RB engines did? Any? If none, then like was asked, what would the tab be there for in the first place? Edit - must be correct valve covers for the non-performance engines with log type manifolds and wire was not routed under valve covers - but was routed over and on top of cover using that tab to access the #7 wire toward firewall as in opposite pass side's #8 wire.
Re: 70 Challenger 440 6-pk Valve Covers [Re: anlauto] #65933
05/30/08 12:01 AM
05/30/08 12:01 AM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
Yep! 70 440 HiPo and 6 pack motors had 2 spark plug wire tabs and 3 wire bundle tabs all on the pass side cover and NO tabs on the drivers side cover. The ones in the pic that are stripped are probably C body covers. If you take your time you can gently grind the 2 offending tabs off and with a bit of filler and paint you're in business! BTW 71 and up used a different cover on the drivers side that had a second "hump" but no hole thru the hump
Re: 70 Challenger 440 6-pk Valve Covers [Re: Classof70Chally] #65934
05/30/08 12:22 AM
05/30/08 12:22 AM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
Just a note: 70' 383 4bbl's have the same valve covers as the '70 440HP and 440-6...I believe.
Re: 70 Challenger 440 6-pk Valve Covers [Re: Classof70Chally] #65935
05/30/08 12:24 AM
05/30/08 12:24 AM
eganville ont
440beep Offline
440beep  Offline
eganville ont
my 71 gtx 440 oct 70 no second hump cover and NO tabs on the drivers side cover
my 71 c- body 383 2bbl 4.71 no second hump has tabs on drivers side cover
anlauto 71 cuda 440 6bbl nov.70 no second hump cover and NO tabs on the drivers side cover
Plymouth's gonna getcha! There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters 71 gtx 440 4speed air grabber blue on blue with white vinyl roof
Re: 70 Challenger 440 6-pk Valve Covers [Re: anlauto] #65936
05/30/08 03:48 AM
05/30/08 03:48 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Alan...Your 99.9% correct...70 V code Sport Fury had the tabbed valve cover...
Re: 70 Challenger 440 6-pk Valve Covers [Re: 1_WILD_RT] #65937
05/30/08 06:02 AM
05/30/08 06:02 AM
anlauto Offline
anlauto  Offline
C bodies don't count
I thought about the "body style" thing after I went to bed last night....how sad is that
The 440-4 I bought for the Barrelcuda has a C Body VIN and had those valve covers as well
Re: 70 Challenger 440 6-pk Valve Covers [Re: 1_WILD_RT] #65938
05/30/08 08:48 AM
05/30/08 08:48 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
what these guys said only C barges with ANY HORSEPOWER big block and all 383-2bbl engines installed in any body platform that was not manual trans equipped used the drivers side cover that routed the #7 wire around the back of the engine in 1970 and 1971 . (actually 68 and up was like this also )
the the 440-6pk engines didn't have SPECIAL valve covers before someone that lie
Re: 70 Challenger 440 6-pk Valve Covers [Re: Classof70Chally] #65939
05/30/08 08:50 AM
05/30/08 08:50 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
i've taken off the tabs and didn't have to add any filler , the only way to tell is if you turn the cover over and see the weld telltales and last i checked show judges do not remove valve covers to see if they are modified
Re: 70 Challenger 440 6-pk Valve Covers [Re: anlauto] #65940
05/30/08 08:52 AM
05/30/08 08:52 AM
Anonymous OP
Anonymous OP
Thanks for all the info. My covers were definitely off a '70 A/C car, so at least I know it was not a 6-pk. I thought the tabs on the driver side were not correct for my car. Sounds like we're in agreement that those pictured by ShakerJoe are correct for my needs (no tabs on driver side cover).
Any other experience with the PlastiDip? I tried the spray PlastiDip, but with six coats, still didn't have adequate buildup. This car is for show, and I am thinking of trying the dip before painting.
Thanks again for all the help.
Re: 70 Challenger 440 6-pk Valve Covers [Re: anlauto] #65941
05/30/08 09:04 AM
05/30/08 09:04 AM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
GITITGONE....Remove the 2 tabs on the drivers side cover and you will have a set of $250.00 1970 440/6 pack valve covers. Those are '70 covers, just not 6 pack ones (indentation on drivers side cover for power brake booster, absence of "hump" that was added to '71 drivers side cover, no indent behind alternator on passenger side like was added in '71.....'71 covers used the same stamping left and right side). If you're not going for Gold, I'd remove the tabs and you'll be the only one that knows they didn't come from the factory that way. I removed them from my covers...
Re: 70 Challenger 440 6-pk Valve Covers [Re: anlauto] #65942
05/30/08 09:32 AM
05/30/08 09:32 AM
Anonymous OP
Anonymous OP
Well, glad to see what people say about this.
My opinion... First, I did the research when the internet was a baby, and did it by looking at cars, books, more cars, and talking to original owners and Chrysler techs from the time.
I will say that the blasted v/c's DID NOT come off a l/c C body engine, but a 71 383 HP that has been in the family since new.
I will also say that they are the same valve covers that have been on all 3 of my 71 Super Bee's, and both of my 70 Roadrunners, all 383 cars. I still have 1 of each the 70 and 71 engines together with these on them.
One of my friends has a personal collection of over 700 cars (yes 700). I was fortunate (unfortunate) enough to spend a lot of time there helping him clean up after he was flooded, and saw MANY low mile original cars. He ran a wrecker and had the highway rights, and pulled in some unique stuff, and his knowledge to me is truly amazing.
I am curious then, who worked on the assembly line here to confirm these "facts"? Here is a scan from the 70-71 parts book:
Notice that the 340+6 valve covers are clearly noted with their own specific part numbers, both left and right, different for 70 and 71. Now note that the 383-440 part numbers are common for all body styles for the right cover, and the only specific one is the left C body. One would think that if there was a specific 440+6 V/C(especially with different bumps/humps), that it would be in the parts book as such.
Now, getting to the assembly line thing, and as was mentioned earlier, did they grind off that tab for the +6 engines? Seems more likely than welding them on to all the others. In my fairly large collection of TSB's I have not come across anything like that. I say never say never or always with Chrysler, so is there anyone here with actual assembly line knowledge to prove/disprove this theory? Anyone have an explanation as to why the Jan. 72 revision of the Chrysler parts book would be wrong?
Re: 70 Challenger 440 6-pk Valve Covers #65943
05/30/08 11:19 AM
05/30/08 11:19 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Off an A/C car ? If a 70 B or E body had a big block with HP exhaust manifolds it would have the EXACT SAME VALVE COVERS as a car without A/C or with the 6pk .
Here's a money saving tip , REMOVE THE TABS , unless you like blowing money .
I did the plastidip , it take 3 or 4 coats , I dipped the tabs and let the cover hang so the drip would be off the end of the tab,then I trimmed off the excess , dipped it again hung it the same way , repeat till you get the thickness you desire .
Re: 70 Challenger 440 6-pk Valve Covers [Re: 6pkaar] #65944
05/30/08 11:21 AM
05/30/08 11:21 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
The weld telltale will still be on the inside. Yes you could sand blast the inside but to me that ruins the cover and it would make it suspect , only a fool would pay 250 for a modified set of covers ...
Re: 70 Challenger 440 6-pk Valve Covers #65945
05/30/08 11:28 AM
05/30/08 11:28 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
no explanation needed ...
IT'S A REVISION .
show me a parts book DATED for when Chrysler first released the part numbers for 1970 parts , I'll go out on a limb and guess that book was dated sometime in 1969 .
as far as you having origanl engines wit hthose valve covers on it that it shouldn't have ? assembly line had to keep going , if the engine assembly line ran out of the covers without those tabs then they used what was available , the line worker wasn't going to STOP and remove the tabs
Re: 70 Challenger 440 6-pk Valve Covers [Re: JohnRR] #65946
05/30/08 11:39 AM
05/30/08 11:39 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
John,do you realize how many "special" things we "try" to create/justify?
