88 chrysler style alternator no int. regulator?
#658077
04/01/10 02:22 PM
04/01/10 02:22 PM
Posts: 1,771 Jamestown, Indiana
James74
Jamestown, Indiana
Long story short, I'm swapping a 440 into an 88 dodge w150. I was going to try to keep the original wiring harness, and with it the original style alternator. Its the Chrysler style (not sure which amp, I assume 90). Its too big to fit in the original style 440 bracket. The manual says it is regulated by the SMEC (computer?). If this is the case, couldn't I swap in an earlier style alt? I was concerned about not having an external voltage reg, but it sounds like the alt I have now doesn't have one either. Any comments or experience on this? Thanks, James
Re: 88 chrysler style alternator no int. regulator?
[Re: Jim_Lusk]
#658080
04/01/10 06:45 PM
04/01/10 06:45 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Just add in the old 70 and up style regulator and wiring, you can get the connectors from NAPA.
