Alcohol (Maintenance) #658009
04/01/10 12:54 PM
04/01/10 12:54 PM
ms
W
w2dak394 Offline OP
w2dak394  Offline OP
W
ms
Thinking about running alcohol in my dak. that im building. What are pros and cons of alcohol? What kind of extra maintenance does it require? Can you run nitrus with alcohol?
Re: Alcohol (Maintenance) [Re: w2dak394] #658010
04/01/10 01:13 PM
04/01/10 01:13 PM
oregon
greendart408 Offline
oregon
I run alky in my motor.... all I do is run a good top lube and at the end of the year take the belt drive pump off and put some oil in it for winter storage. I also at the end of the day running the car plug all the vents to the tank. This keeps corrosion from forming...Also get it up to temp 190 os so before shutting it off as this burns the moisture out of the oil. I have had zero problems doing it this way.
Re: Alcohol (Maintenance) [Re: greendart408] #658011
04/01/10 01:33 PM
04/01/10 01:33 PM
sg66mopar Offline
sg66mopar  Offline
I have to do this same procedure running race gas because of the aluminum motor. I think it's a good idea with any race motor just to keep the rust inside to a minimum.
Re: Alcohol (Maintenance) [Re: greendart408] #658012
04/01/10 01:38 PM
04/01/10 01:38 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
How many years have you been running alky?
Re: Alcohol (Maintenance) [Re: Challenger 1] #658013
04/01/10 01:46 PM
04/01/10 01:46 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
no more maintenance than gas really. Long as your tuneup is good. I run Klotz Uplon toplube with a Moroso vac pump and pretty much maintenance free. I change oil 25-30 passes but do the same on my gas motor. Been running all kinds of alky systems over 10years.
Re: Alcohol (Maintenance) [Re: Challenger 1] #658014
04/01/10 02:48 PM
04/01/10 02:48 PM
oregon
oregon
I also run a star machine vac pump.. been running it for 2yrs....
