Re: What's your favorite electric cut-out?
[Re: DaytonaTurbo]
#657868
04/01/10 07:53 PM
04/01/10 07:53 PM
Posts: 12,296 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I hope the newer QTPs are better than the older ones. I had a lot of trouble with mine. Motors coming loose from the mounts, butterflies coming off the shafts, leaks, etc.
I sent them back twice, which was an experience all by itself. QTP was more than a little difficult to deal with on getting the issues addressed. I finally put in longer motor attaching screws with locktite and had the butterflies welded to the shaft.
That finally dealt with those problems, but they still leaked. So last year I just removed them and installed Dougs.
If you are going to go with the less expensive butterfly type of cut-outs, check out McCords.
Master, again and still
[Re: 63stabamatic]
#657869
04/01/10 08:51 PM
04/01/10 08:51 PM
Posts: 5,447 So Cal
Sinitro
So Cal
We got 1 of the 1st set from Doug Thorley, they work and seal very well. Also then the price was much lower, but now they have almost doubled in $ cost. Also we have seen the QTPs leak badly... Just my $0.01...
