Which oil? #657789
04/01/10 09:02 AM
04/01/10 09:02 AM
Home of the Bluegrass
MoparJunkie Offline OP
Okay guys, this is an age old question again.... Which oil should I run for my 440???? New build break in and regular maintenance???
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: Which oil? [Re: MoparJunkie] #657790
04/01/10 11:42 AM
04/01/10 11:42 AM
S.E. Conn
Hoof Hearted Offline
S.E. Conn
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: Which oil? [Re: Hoof Hearted] #657791
04/01/10 11:56 AM
04/01/10 11:56 AM
Aurora Colorado
BELVEDERE67 Offline
mopar addict
BELVEDERE67  Offline
mopar addict
Aurora Colorado
Yes it's been asked alot before. For breakin, I've used Rotella 10-40. There has been some question about the zinc composition which is needed during break-in. I found some STP red bottle additive which is supposed to have alot of zinc. GM EOS oil supplement is also good but getting hard to find for some. After break-in, it's just your own preference. I like Castorol because it seems to hold good oil pressure compared to others. Bottom line change oil often
Re: Which oil? [Re: MoparJunkie] #657792
04/01/10 12:01 PM
04/01/10 12:01 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
I switched to VR1 20/50 racing oil because its easier to get than the Brad Penn I was using. Has more phosphorus & zinc than most. Check out www.bobistheoilguy.com Great site about oils, etc.
Re: Which oil? [Re: MoparJunkie] #657793
04/01/10 12:05 PM
04/01/10 12:05 PM
hmmm lets see. for my engine breakin I used the cheapest oil wallmart had (10w30) along with superweak valvesprings. after cam breakin and a hour to change back to the good springs. twas good to go. and for 'regular' running I use the cheapest oil wallmart had (10w30), changed every 2000miles w/ new filter and again with no problems.
Re: Which oil? #657794
04/01/10 02:10 PM
04/01/10 02:10 PM
jamestown, ny
71scamp440 Offline
Hinged
71scamp440  Offline
Hinged
jamestown, ny
now i might not know alot, but your looking to wipe out your cam. unless you have a newer car that cheap walmart oil is not what you want. you need an oil rich with zinc , or you need to use some zinc additive with the walmart oil. just my . i use the brad penn green oil. st 30 for break in, and 10w30 after break-in
71 scamp big block with 915 heads 727 trans
Re: Which oil? [Re: 71scamp440] #657795
04/01/10 02:14 PM
04/01/10 02:14 PM
and I know less then pretty much anybody. BUT I do know that I never wiped any cam during breakin. many many years of good service. zinc this and that is all marketing hype. todays oils, even the cheap stuff is vastly superior to anything refined 30+ years ago.
Re: Which oil? #657796
04/01/10 02:21 PM
04/01/10 02:21 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You have been lucky so far. The zinc has been pretty much taken out of the new oils and that makes them bad for the old tech cams. The new roller and overhead cams don't need the zinc but or flat tappet cams do.
Re: Which oil? [Re: stumpy] #657797
04/01/10 02:24 PM
04/01/10 02:24 PM
Jamestown, Indiana
James74 Offline
James74  Offline
Jamestown, Indiana
is the zinc needed just for break in, or do flat tappet engines continue to need zinc? From what I read, I got the idea that new oil probably still has enough zinc for lubrication once the cam is broken in?
Re: Which oil? [Re: James74] #657798
04/01/10 02:26 PM
04/01/10 02:26 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Once the cam is broken in then the normal oil will have enough zinc in it to control excessive wear.
Re: Which oil? [Re: 71scamp440] #657799
04/01/10 02:35 PM
04/01/10 02:35 PM
Florida STAYcation
dOOc Online penguin-006
The village idiot's idiot
dOOc  Online Penguin-006
Florida STAYcation
Just a note ... the WallyWorld oil has the same spec as most good oils out there B U T ....
I would agree that HE is lucky that he does not wipe-out the cam with super-weak valve-springs.
ACCORDING to some of the cam literature I have read .. if you do not have proper-pressure on the lifters .. the lifters will not correctly rotate.
Re: Which oil? [Re: dOOc] #657800
04/01/10 02:46 PM
04/01/10 02:46 PM
nah... there just my "break-in" valvesprings. makes my life easier.
Re: Which oil? #657801
04/01/10 09:25 PM
04/01/10 09:25 PM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
Use a good quality oil like Castrol or Valvoline and a zinc additive like ZDDP.
Re: Which oil? [Re: moparcanuk] #657802
04/01/10 09:44 PM
04/01/10 09:44 PM
IN
ahy Offline
ahy  Offline
IN
Current car oils have around 500-600 PPM zinc. Most say you need 1100 - 1300 with a flat tappet cam. More with high spring pressure. Always.
Cam companies, engine builders and car mags have written about this. Lots of posts about flat cams kinda prove it.
There are lots of solutions to this folks have used. Adding ZDPP or GM EOS to regular car oil is one. Some 20W-50 racing oils have higher zinc (and some dont't I believe). There are speciality classic car oils and 4 stroke motorcycle oils with high zinc.
I choose diesel engine oil. Rotella T in 10W-30 or 15W-30. Its readily available and reasonably priced. It still has 1100-1200 PPM zinc. I add STP for insurance. For break in add EOS, ZDPP or STP.
Re: Which oil? [Re: ahy] #657803
04/02/10 05:56 AM
04/02/10 05:56 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Here's a recent article on motor oil from Mopar Muscle Magazine:
Choosing The Best Oils For Your Mopar Engine - Lifeblood; Dave Young, March, 2010 issue of Mopar Muscle - link
All oils perform the same duties, but some perform them better than others. What factors do you consider when choosing a motor oil? - Dave Young, March, 2010 issue of Mopar Muscle Magazine
Re: Which oil? [Re: James74] #657804
04/02/10 09:54 AM
04/02/10 09:54 AM
jamestown, ny
71scamp440 Offline
Hinged
71scamp440  Offline
Hinged
jamestown, ny
i still use the zinc oil after break in. i might not have to, but i am not willing to risk the $300 cam.
