Re: 440 trucks
[Re: Fargo Freek]
#6568
06/06/06 02:43 PM
06/06/06 02:43 PM
Posts: 362 Nashville, TN
Chief_Plasma
Nashville, TN
Hey this might be a dum a$$ question BUT what is stopping the engine from tipping back and hitting the firewall when there is no tanny there ?????
Motor mounts and the radiator hose i bet! lol
-cp
Re: 440 trucks
[Re: 70Challengerse]
#6570
06/06/06 09:57 PM
06/06/06 09:57 PM
Posts: 7,512 Lebanon ,PA in the Susquehanna...
70Challengerse
Ok,Got the trans against the block,have to admit , went right into place,has enough torq convertor space,only thing I have noticed,around the rear support is tight and I extended the pressure switch for clearance,gonna have to make alittle room around the support,about a 1/2 inch of so for the correct angle,this is a quick pic and is not finished,gonna raise the trans about another 1/2 inch,so far the only fabrication is gonna be for the shifter linkage,gonna install a Lokar kit for throttle pressure,gonna finish up some small crap tomorrow,hopefully this weekend ,if the driveshaft is done a trail test on the lift...
Re: 440 trucks
#6575
06/07/06 12:14 PM
06/07/06 12:14 PM
Posts: 762 Ca
76440
Ca
Done this thousands of times new mounds and no baby block distr to hit.....
Spoken like a true trans "expert."
Re: 440 trucks
[Re: dynotune440]
#6582
06/09/06 08:49 PM
06/09/06 08:49 PM
70Challengerse
Don't feel like pics tonight,(tired) the trans is all the way in ,cept for the shifter bracket,driveshaft fits great, hope to move it tomorrow,gotta wire the hot wire yet,made the new cooler lines tonight,getting there..Carlisle is starting to look better...
