8-3/4 Axle Bearings #657703
04/01/10 07:16 AM
04/01/10 07:16 AM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
Its been awhile since I messed with one.
You can`t run just one "green" stlye bearing right?
No way to set endplay,must be in pairs. Right?
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: 8-3/4 Axle Bearings [Re: 6bblFLASH] #657704
04/01/10 07:46 AM
04/01/10 07:46 AM
scratchnfotraction Offline
i would think 1 on the non adjusted side might work
no endplay adjustment with 2 greens (1-set)
with thrust block or with out thrust block
but why would you run only 1 side??
I replaced the first set after 10yrs,2 yrs on the new set
daily driver
Re: 8-3/4 Axle Bearings [Re: scratchnfotraction] #657705
04/01/10 04:57 PM
04/01/10 04:57 PM
N.E. Ohio
N.E. Ohio
Cause I have a bad green bearing and have stock ones.
Re: 8-3/4 Axle Bearings [Re: 6bblFLASH] #657706
04/01/10 06:37 PM
04/01/10 06:37 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I don't think that I would try it. even if you have the adjuster green bearings are not made to apply or to have preload applied to them and you have to preload the tapered bearings.
Re: 8-3/4 Axle Bearings [Re: MoparforLife] #657707
04/01/10 08:23 PM
04/01/10 08:23 PM
Morris County NJ
Rustydog Offline
Rustydog  Offline
Morris County NJ
I have one car with a dana 60. On the right side is a green axle bearing and on the left side is a conventional bearing with the adjuster on that side. The center section is a PowerLok that has the center part that touches the end of each shaft. Its not the full floating type.
Everything works great and has been working great for several years. I know its weird. Usually the adjuster is on the right side. I got it this way.
But it works great.
