Re: Timing chain replacement on a Big Block 400
[Re: RapidRobert]
#657652
04/01/10 09:50 AM
04/01/10 09:50 AM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
Thats the way I do them.It takes a little time to get the bolt out.If you cruch or snap off the heater nipple it becomes a major job.Rocky
Chrysler Firepower
[Re: HPMike]
#657653
04/04/10 08:53 PM
04/04/10 08:53 PM
Posts: 4,102 Cochise County Arizona
SPWC
Leave the pipe nipple alone. If it's been in there for any appreciable time, you will spend way more time and aggravation trying to get it out then you would just running a wrench behind the nipple and backing it out.
It's just not that hard.
MB
Did as suggested,and just took off the P/S pump and Alt. Removed all the bolts holding the housing on,and then just went little by little on the bolt behind the nipple. It honestly looks more difficult than it actually is.
Reassembly may be a little tougher though...Thanks for the words of wisdom
[Re: SPWC]
#657658
04/04/10 11:16 PM
04/04/10 11:16 PM
RapidRobert
Haven't tried it yet but recommended to heat the nipple threads at the bottom and melt in some beeswax (household candle?) into the threads and it'll come right out which will save your gas
[Re: SPWC]
#657660
04/05/10 02:05 PM
04/05/10 02:05 PM
RapidRobert
you want it on TDC #6 compression so put the harmonic dampener timing marks at TDC with the dist rotor at the #6 plug wire. This'll put the dots at 12 o'clock on the small bottom crank gear and 6 o'clock on the top large can gear & you're ready
[Re: RapidRobert]
#657662
04/05/10 03:17 PM
04/05/10 03:17 PM
SPWC
Did as suggested and your experience paid off.The dots are totally lined up...Awesome,Thanks for the tips!! I have taken some pics of the chain as its currently installed. According to the pics,is this chain in need of replacement? Looks to have alot of slack in it. Regardless,im in there,have the replacement parts,the truck has 93k miles...Might as well do the job. Im doing this job because the truck has no power,and it backfires,"sounds" like its backfiring in the crankcase.I was told the Timing Chain may be suspect,so thats why im doing this. And lastly,YES that Fram filter will be coming off once I get it running again.
[Re: SomeCarGuy]
#657664
04/05/10 04:30 PM
04/05/10 04:30 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Yep, change it. After you get the gears and chain off, stuff a rag down into the front of the oil pan to keep ann the junk out when scraping the gaskets off. Make sure the front cover is flat and clean. Remove the rag before installing parts! If you are going to change the oil before starting, you can rinse any slime down into the pan. No chunks or stuff that will clog the pickup though! It's a good time to install a front seal too.
Start all the front cover bolts, then the oil pan bolts. Then tighten. The harmonic balancer will not slide on, so you will need a hammer, chunk of wood and be careful of the radiator (shade tree style) or a balancer installer (rent?)
If you are doing an engine cleanup at the same time, paint the front cover and the back of the water pump housing before putting the housing on. Clean and paint the timing marks too.
The balancer and pulley should align only one way, it might help to figure this out and have an alignment mark before it's way down in that engine bay...
[Re: RodStRace]
#657665
04/05/10 04:47 PM
04/05/10 04:47 PM
RapidRobert
rent a harmonic balancer installer to draw it back onto the crank smoothly and w the cover loosely back on, tighten the pan bolts to draw the cover/gasket downward to help line up the TC to block bolt holes in the front on the block if need be, then snug everything down evenly keeping an eye on the gasket at the bottom.
