Re: Polyester Resin
[Re: cougar_cat_25]
#657403
04/03/10 12:55 AM
04/03/10 12:55 AM
Posts: 1,572 Jacksonville Florida
elitecustombody
Hey everyone whats the scoop on the best "Bondos"? I know Bondo is good but is it top of the line?
are you asking about polyester filler to repair and smooth out imperfections or repairing a fiberglass boat?
Rage Extreme would be the best polyester filler,it can cost over $50 a gallon depending where you buy, Rage Gold would be second best,Rage and Z-Grip third,
Not sure why Doc brought up chopped strand fiberglass filler,generally it's not the best choice when repairing minor waves or dings ,but if you must have fiberglass reinforced filler, get Everglass, Dynaglass is garbage compared to Everglass,
And if you're working with any fillers,especially fiberglass reinforced fillers, do yourself a favor and pick up a cheese grater ,it can save you hours of sanding and alot of sandpaper,
Re: Polyester Resin
[Re: SportF]
#657406
04/03/10 02:31 PM
04/03/10 02:31 PM
Posts: 21,855 Kirkland, Washington
Pacnorthcuda
As I said above I never noticed any real differences between the brands. Can you tell me what makes that "gold stuff" better? Does it sand easier? Really curious here. Thanks
The higer quality fillers will sand easier and also less susceptable to pinholes from tiny air bubbles.
Re: Polyester Resin
[Re: Pacnorthcuda]
#657407
04/03/10 07:09 PM
04/03/10 07:09 PM
elitecustombody
also they are usually tack-free and have less chance of shrinking, and also have alot less weight to it
