front suspension changes #657136
03/31/10 03:57 PM
03/31/10 03:57 PM
W.Va
fowl play Offline OP
W.Va
a few days ago someone hsd a post about doing away the torsion bars and going to coil over shocks. there were some pictures of the lower control arm with the locating bolt being drilled and a bolt and washer holding it on. have a lot of people done this and is holding up ok? i would like to know more about this. it would free up space in there. this is on an a body car for race use only with a smallblock. thanks
Re: front suspension changes [Re: fowl play] #657137
04/01/10 05:43 PM
04/01/10 05:43 PM
tboomer Online work
tboomer  Online Work
Re: front suspension changes [Re: tboomer] #657138
04/01/10 07:27 PM
04/01/10 07:27 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Lots of that done by many works just fine..
Re: front suspension changes [Re: VernMotor] #657139
04/01/10 07:32 PM
04/01/10 07:32 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
3 years on mine and still tickin'
Re: front suspension changes [Re: dartman366] #657140
04/01/10 07:47 PM
04/01/10 07:47 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
I'm thinking about doing this too. What size bolt did you guys drill and tap for?
Re: front suspension changes [Re: Dartin] #657141
04/01/10 09:13 PM
04/01/10 09:13 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
3/8-24 grade 8.
Re: front suspension changes [Re: dartman366] #657142
04/01/10 09:27 PM
04/01/10 09:27 PM
K
Kiddart Offline
Kiddart  Offline
K
does someone have a power point or some good pictures
Thank you
Kiddart
Re: front suspension changes [Re: Kiddart] #657143
04/02/10 07:39 AM
04/02/10 07:39 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Is this something suitable for street use? I guess the strut rod takes most of the braking force etc. Thanks.
68 Barracuda Formula S 340
Re: front suspension changes [Re: Bad340fish] #657144
04/02/10 08:10 AM
04/02/10 08:10 AM
Ms.
Dartwizer Offline
Dartwizer  Offline
Ms.
Not to hijack this,but what shocks and springs?
