im workin on a 70 challenger 340,4spd,3.55s..im new to small block..was wondering if anyone is running eddy rpm cam and if its a good street cam. im building a mild 340,ld340 intake,650 to 750cfm carb,floating 10.5 forged pistons,stock bottom end,steel crank..im gonna run either j heads or a set of magnum heads i just picked up..
any input or other cam suggestion would be appreciated,,tia...
