Re: Re-using Cometic gaskets
[Re: torkrules]
#656741
03/31/10 08:48 AM
03/31/10 08:48 AM
Posts: 84 NC
Badfish67
NC
I just reused mine with no issues and have about 10 passes on the motor so far with no leaks.
1967 Barracuda
360ci/727
9.723ET @139.44mph
[Re: roadhazard]
#656743
03/31/10 09:13 AM
03/31/10 09:13 AM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
I know people have re used them with good luck. But keep in mind a Hemi with aluminum heads are way more finicky and less forgiving when it comes to water seepage then a wedge motor. Cometic does not reccomend re using them. Are you going to run the motor on the dyno again? I saw your earlier post and your talking about changing heads from MP to stage V. If your going to a completly different head you should get new gaskets. Also my opinion if your keeping the same head, and going to dyno the motor maybe roll the dice. but id hate to get a motor in the car, and have to pull the heads, to me that isn't worth the savings.
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
[Re: HemiDart68]
#656744
03/31/10 01:46 PM
03/31/10 01:46 PM
Posts: 2,864 IN
Irun5snd8th
IN
I got 5 re uses out of my last set but they started leaking water (unbeknownst to me) in 2 cylinders on the last re use
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
[Re: TheOtherDodge]
#656746
03/31/10 07:20 PM
03/31/10 07:20 PM
I have reused some ragged looking Cometics time and time again--3 at least--quick spray with Holomar ( Gosh! that stuff is $$$ ) and away you go no worry--honest two to three times is FINE!
[Re: HemiDart68]
#656747
03/31/10 08:03 PM
03/31/10 08:03 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Tim Banning said the same thing. Since the heads are being changed he advised to replace the gaskets. Right now for me what Tim says goes. If he told me my problems would go away if I chewed aluminum foil, I'd buy every roll I could get my hands on.
