I just installed Dr Diff's offset shackle setup and on my 'cuda. I have a narrowed, by three inches rear end (1 1/2" per side). I ended up with 5.5 inches before spring interference so with a stock rear you will have 7 inches. The The Dr Diff kit is a 1" offset where a Mopar Perf. kit is a 3/4 offset and reqires Super Stock springs. With the 1" kit it does not allow full use of the wheel house, I believe the Doc offers greater offsets but on the 'cuda you have to modify the rear valance and with the Challenger it should not.
