Cal Trac #655379
03/29/10 09:17 PM
03/29/10 09:17 PM
UK
602heavy Offline OP
602heavy  Offline OP
UK
68 Charger weighs around 4400lb , the pas side leaf is bent so car is listing around 1 1/2" , anyone had these retempered? , gonna take them down to a spring shop tommorow , will also get another leaf added to the rear leafs , anyone done this? , rear springs took a hammering last season on the spray.
Re: Cal Trac [Re: 602heavy] #655380
03/29/10 09:21 PM
03/29/10 09:21 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Call Calvert and see what they say.I broke a spring a couple years ago and they sent me new ones,and a call tag to send the old ones back for inspection.No cost to me at all.
Re: Cal Trac [Re: Dunnuck Racing] #655381
03/29/10 09:23 PM
03/29/10 09:23 PM
UK
602heavy Offline OP
602heavy  Offline OP
UK
Thanks , will give them a call.........just think the weight is gonna cause issues with any type mono leaf , which is the reason i thought about adding a leaf for belt & braces.
Re: Cal Trac [Re: 602heavy] #655382
03/29/10 09:34 PM
03/29/10 09:34 PM
Northern Indiana
Northern Indiana
I see your point,that's a pretty heavy car,but they do have a couple different spring rates for their monoleafs.Maybe they will want to change the ones you are using?
Re: Cal Trac [Re: Dunnuck Racing] #655383
03/29/10 10:01 PM
03/29/10 10:01 PM
UK
602heavy Offline OP
602heavy  Offline OP
UK
Just hope these arn't the heavier one's Calvert supplied , seem to remember these were ordered with the weight in mind , these are two years old , will see what they suggest.
Re: Cal Trac [Re: 602heavy] #655384
03/29/10 10:12 PM
03/29/10 10:12 PM
still waiting on 684
K
Kiner Offline
Kiner  Offline
K
Call John You need the number off the sticker.He will tell you the spring rate.
Re: Cal Trac [Re: Kiner] #655385
03/29/10 10:18 PM
03/29/10 10:18 PM
UK
602heavy Offline OP
602heavy  Offline OP
UK
What's left of the sticker can't be read as the writing had fadded away.
