Any thoughts on my data recorder graph?
#654080
03/28/10 07:42 PM
03/28/10 07:42 PM
Posts: 136 Dallas, TX
440Brian
Dallas, TX
I'm still trying to learn and analyze my data recorder runs. It's from late last year, an 1/8mile run, 6.944sec@96.40mph, RT.031, launch set for 3k, shift set for 5800 (727 trans with brake). It shows engine rpm, driveshaft rpm, converter slip calculation, and battery voltage. The zero time is set for the first movement of the driveshaft. The converter slip gets down to about 15% on 1/4 mile runs. Any thoughts or comments, especially anyone with data recorder experience? Thanks for your input.
Re: Sorry the attachment is too big, solutions?
[Re: 440Brian]
#654084
03/29/10 11:32 PM
03/29/10 11:32 PM
Posts: 614 new jersey
gillman34
new jersey
I think I can get it to work now. Thanks for the help 540dust and Metalstorm.
Tire slipped at about .5 sec into it what's with the rpm fluctuations? all that bouncing around? do you have traction control?
[Re: 540dust]
#654088
03/30/10 09:21 PM
03/30/10 09:21 PM
440Brian
Dallas, TX
The engine is running fine, no misses. I've got a Autometer tach connected to the same terminal on the MSD 7AL-2. The instructions warn about noise and routing the wiring away from anything electrical. Maybe I should try disconnecting the tach for a run? Thanks for confirming the excessive noise.
[Re: gillman34]
#654090
03/30/10 10:10 PM
03/30/10 10:10 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Even the speed is noisey.... you might try putting a filter in the power line going to the logger... both my rpm and speed are much smoother ![](/ubbthreads/images/graemlins/wave.gif)
[Re: gillman34]
#654091
03/30/10 10:10 PM
03/30/10 10:10 PM
Posts: 656 Kokomo, IN
540dust
Kokomo, IN
rpm should look like this..., Open attachment and view full screen, top trace is rpm second driveshaft, bottom is battery voltage.
[Re: 440Brian]
#654096
03/31/10 04:56 PM
03/31/10 04:56 PM
MR_P_BODY
Thanks for posting a picture of your graph. The little bump in driveshaft rpm at the shift, is it just some tire wrap-up or something else? How do you know if the tire lost traction and spun a little?
You will see the speed go up then drop then continue at the rate of increase like normal... also watch the rpm go up.... always look at both lines to see if they correlate ![](/ubbthreads/images/graemlins/wave.gif)
