300hp magnum crate 360 convert to 380hp? #653937
03/28/10 06:43 PM
03/28/10 06:43 PM
eastern long island,NY
JeepJimmy Offline OP
has anyone converted the magnum 300hp 360 MP crate motor to the 380 hp model. from what i can find its only the cam and to a single plane intake. any ideas??
70 duster 360magnum, 1975 jeep j-10.
Re: 300hp magnum crate 360 convert to 380hp? [Re: JeepJimmy] #653938
03/28/10 08:21 PM
03/28/10 08:21 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
Are the pistons/compression the same?
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: 300hp magnum crate 360 convert to 380hp? [Re: Rapid340] #653939
03/28/10 08:29 PM
03/28/10 08:29 PM
Bama
BigDawg72 Offline
BigDawg72  Offline
Bama
Everything I have seen quotes the 380hp engine at 9:1. I am using the 380HP recipe to build my 360 and have done a fair amount of research. The stock magnum engines (according to my Haynes manual) are listed at 9:1 so I would ASSUME the pistons would probably be the same? I haven't seen a compression figure for the 300 or 320 versions though.
Re: 300hp magnum crate 360 convert to 380hp? [Re: BigDawg72] #653940
03/28/10 08:46 PM
03/28/10 08:46 PM
Costa Mesa, CA
chache876 Offline
chache876  Offline
Costa Mesa, CA
I'm pretty sure the pistons were 9:1 in the 300hp version
Re: 300hp magnum crate 360 convert to 380hp? [Re: chache876] #653941
03/29/10 12:05 AM
03/29/10 12:05 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The pistons are different and slightly higher compression, the 380 HP motor I saw come appart had pistons with 2 valve releifs instead of the soap dish production pistons and 300hp pistons. They were below deck but I don't know how much but they would give a slightly higher compression.
Re: 300hp magnum crate 360 convert to 380hp? [Re: HotRodDave] #653942
03/29/10 12:16 AM
03/29/10 12:16 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
The pistons are different and slightly higher compression, the 380 HP motor I saw come appart had pistons with 2 valve releifs instead of the soap dish production pistons and 300hp pistons. They were below deck but I don't know how much but they would give a slightly higher compression. [/quote
Re: 300hp magnum crate 360 convert to 380hp? [Re: HotRodDave] #653943
03/29/10 03:36 AM
03/29/10 03:36 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I thought the 300 horse 360 crate came with stock truck 360 pistons and regular magnum heads where the 380 horse crate 360 came with the magnum r/t heads. Not sure on the pistons on that one.
Re: 300hp magnum crate 360 convert to 380hp? [Re: DaytonaTurbo] #653944
03/29/10 09:54 AM
03/29/10 09:54 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Change the cam, springs, retainers, and intake and you're done.
Here's the evolution of those two engine programs:
300 and 380 initially came with a stock long block right from the Saltillo Mexico engine line. Both had stock magnum heads. 380 got the cam, springs and retainers changed....300 did not.
Then MP ran Chrysler completely out of OE magnum heads, the OE supplier wasn't interested in making them anymore, and it probably would have cost 500k or more to modify the tools to fit a different foundry line.....So, enter the R/T heads and plan B:
320 and 390 had R/T heads and started out with stock Saltillo shortblocks.
That worked fine for awhile, but it wasn't long before MP ran Chrysler completely out of new OE shortblocks...and it was time for plan C:
They both got .020 over reman shortblocks with FM hypereutectic pistons, R/T heads, and otherwise the same specs as before.
380 had a stock piston.
390 in it's final, .020 over form had a better piston with a couple vavle reliefs.
390 in it's very first form had a stock piston.
Rich H.
Esse Quam Videri
Re: 300hp magnum crate 360 convert to 380hp? [Re: JeepJimmy] #653945
03/29/10 06:13 PM
03/29/10 06:13 PM
Thanks Zippy, i could not get a correct answer from anyone. trying to find a PN breakdown of the motors. i know i saw one years ago.. Wonder how it will work keeping the dual plane. its not a drag car.
Re: 300hp magnum crate 360 convert to 380hp? [Re: ZIPPY] #653946
03/29/10 08:00 PM
03/29/10 08:00 PM
Southern Cal
Noblewk Offline
Noblewk  Offline
Southern Cal
Plan D. While making the 402 stroker the R/T heads were adapted to "Big valve" heads. The remainer of the R/T "Big Valve" heads were used in the last production run. All crates were put together my Cummins. You will find a Cummins Date tag/Serial# on the blocks "pass side on the Bell mount"
66 Dart GT, 402 11.18:109 Best 63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best 2000 Ram 2005 Durango Hemi.
Re: 300hp magnum crate 360 convert to 380hp? [Re: goldmember] #653947
03/29/10 09:11 PM
03/29/10 09:11 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Thanks for the aditional insight there, very helpful
Re: 300hp magnum crate 360 convert to 380hp? [Re: ZIPPY] #653948
03/29/10 09:48 PM
03/29/10 09:48 PM
Bama
BigDawg72 Offline
BigDawg72  Offline
Bama
Zippy... Thanks for a very informative post!
To the OP, I am using the Professional Products Airgap RPM knockoff in my build and was told by someone knowledgeable on the magnum engines that it should produce more HP than the Mopar M1 single plane intake. They stated that the M1 wasn't a great intake.
If my Flamethrower distributor would hurry up and get here I would fire mine up and have some real feedback on the combo. It does make me feel confident that my 400-425 HP goal is attainable since the same cam was/is used on the 380, 390, and 435 horse crate engines. I know it's all in the heads, but I hope to see the high side of 400 with my slightly cleaned up plain magnums. Maybe I' m too optimistic...
Re: 300hp magnum crate 360 convert to 380hp? [Re: BigDawg72] #653949
03/29/10 11:19 PM
03/29/10 11:19 PM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
I'll confirm that my 380 horse Magnum didn't have the R/T heads. I reused the block when I stroked the motor after it spun a bearing on me... sold the heads on ebay in favor of Eddys.
Re: 300hp magnum crate 360 convert to 380hp? [Re: HotRodDave] #653950
03/29/10 11:52 PM
03/29/10 11:52 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I was picturing you looking at the valve reliefs and doing the math in your head,then the distance down by eyeball and more speculating. Thats real helpful!
Re: 300hp magnum crate 360 convert to 380hp? [Re: goldmember] #653951
03/30/10 07:03 AM
03/30/10 07:03 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
upgrading a 300HP mag motor for a street car, I think I'd use a cam like a hughes 1828, not something as big duration wise as the 380 horse motor. Zippy, I thought the 300HP motors got the upgraded springs, too.
the dual plane isn't a bad piece, it's on par with a stock LA 4bbl intake. an edelbrock air gap would probably be worth an additional 15-20 HP...
the M1 single plane is a good intake, probably makes about the same or a touch more HP as the air gap, but like most single planes, is probably down 15-20 lb ft of midrange torque over the air gap or the dual plane....
2017 Grand Cherokee Overland
Re: 300hp magnum crate 360 convert to 380hp? [Re: BigDawg72] #653952
03/30/10 08:59 AM
03/30/10 08:59 AM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
My 360 is putting down 340 whp on a dynojet chassis dyno, so with 20% drive train loss comes right at 425 hp (727 transmission, ford 9" rearend). I run Edelbrock heads (not ported, out of the box), RPM Air-Gap, 10.2:1 compression ratio, holley 750 VS carb, headers and dual 2.5" exhaust, and a crane retro-fit roller cam (112 lsa, 107 installed, 230/238 @ .050, .528/.538 lift). If your combo is close to this you should be able to see similar numbers I'd think
Re: 300hp magnum crate 360 convert to 380hp? [Re: JeepJimmy] #653953
03/30/10 09:57 AM
03/30/10 09:57 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
The 402 really didn't enter into the conversation but since someone mentioned it, it was not really a plan D relative to the 360-380/390. It was sold at the same time the 390 was available.
There is a new low cost 4" stroke, reman-style, magnum head MP crate engine hopefully coming online this summer. I'm not going to post the part number until it's been activated, however the directional MSRP is currently $5419 so that's a good sign. Given the pieces in it, it should run as hard (or better) than the older version.
On the intake....for a 3.58 stroke combination using a dual plane instead of a single plane really isn't a huge handicap, depending on the car. Usually the dual plane will outrun the single plane on a street oriented 3.55 gear, 2400 stall type of car.
Re: 300hp magnum crate 360 convert to 380hp? [Re: ZIPPY] #653954
03/30/10 10:10 AM
03/30/10 10:10 AM
Southern Cal
Noblewk Offline
Noblewk  Offline
Southern Cal
The plan D had to do with the "Big Valve" R/T heads on the last group of 360/390 crates. The earlier versions of the combo received the standard R/T head combination.
Re: 300hp magnum crate 360 convert to 380hp? [Re: Noblewk] #653955
03/30/10 10:32 AM
03/30/10 10:32 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
True, point taken and that's correct.
Re: 300hp magnum crate 360 convert to 380hp? [Re: ZIPPY] #653956
03/30/10 12:29 PM
03/30/10 12:29 PM
Kansas, USA
V
Venomvpr900 Offline
Venomvpr900  Offline
V
Kansas, USA
That would be better then the $10,000 they have the 405hp 360 listed for. What a rip
1987 D-100 SWB, 390hp/360ci Mopar Performance Crate, Built 998 trans, 9.25 axle with sure-grip and 3.92's - 3960#'s with driver 13.83 @ 96.36 1.98 60 ft 2003 Dodge Ram 2500 HD 5.7ltr HEMI!!!
