71 Demon TTI Headers Indy heads. Clearance problems! #653626
03/28/10 02:59 PM
03/28/10 02:59 PM
North East Missouri
E
express Offline OP
express  Offline OP
E
North East Missouri
Buddy of mine has this problem. His son was building a 71 Demon. 340 with Indy heads & TTI headers. Factory 340 4 speed, manual steer car.
Problem is the steering hits on the pass side real bad. Can't even turn the wheel! Looks like the engine would have to come back at least one inch & maybe up to clear. Any ideas?
His son died before this was sorted out & Dad is not sure of what is what.
I do know headers are 340A-C-4.
Thanks, Doug
cny25421@centurytel.net 70 Duster Turbo Charged 79 Lil Red Express Bonded Locksmith
Re: 71 Demon TTI Headers Indy heads. Clearance problems! [Re: express] #653627
03/28/10 07:51 PM
03/28/10 07:51 PM
North East Missouri
E
express Offline OP
express  Offline OP
E
North East Missouri
Bump.
Re: 71 Demon TTI Headers Indy heads. Clearance problems! [Re: express] #653628
03/29/10 02:23 AM
03/29/10 02:23 AM
New Jersey
U_Code_Cuda Offline
U_Code_Cuda  Offline
New Jersey
I am having the same problem with Hooker super comps on my Demon...Sounds like a similar setup and same results...see my post... no help from the board,
https://board.moparts.org/ubbthreads/show...rue#Post5878688
1970 R/T Challenger 4-speed
1971 Demon 340 3-speed
Re: 71 Demon TTI Headers Indy heads. Clearance problems! [Re: U_Code_Cuda] #653629
03/29/10 02:28 AM
03/29/10 02:28 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i think the crank centerline should be like 5 1/4" from the k frame i had to shim the bottom of the engine mounts. might want to check TTI web site maybe a pdf file on instructions if he is missing them. Not 100% but if it was a 6cyl car it might not have the correct center link that drops down?????
Re: 71 Demon TTI Headers Indy heads. Clearance problems [Re: ademon] #653630
03/29/10 10:07 AM
03/29/10 10:07 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I had to shim my motor mounts and notch the k-frame on one side to slide the engine back about 1/4". Headers ended up fitting without needing dents. Make sure you read the TTI install instructions. They have specs on where the engine should be located. You can download them from the TTI web site. I run the Schumacher Torque Strap which keeps the engine from moving around so the headers never hit anything.
Re: 71 Demon TTI Headers Indy heads. Clearance problems [Re: 69Cuda340S] #653631
03/29/10 10:22 AM
03/29/10 10:22 AM
North East Missouri
E
express Offline OP
express  Offline OP
E
North East Missouri
It is a factory 340 car that has been in the family for 35 years.
Are any of you guys running Indy heads? I think this adds to the problem. Don't know if the Indy's moved the ports down?
At this point it looks like shimming the engine up would not be enough, it needs to go back an inch & that going to throw everything else off.
Bad thing is its been sitting for 3 years since his son died. He is just now getting to where he wants to see it done. I will take some pics the next time I am out to his place.
Thanks, Doug
Re: 71 Demon TTI Headers Indy heads. Clearance problems [Re: express] #653632
03/29/10 11:02 AM
03/29/10 11:02 AM
NY usa
540challenger Offline
NY usa
Thanks, Doug
The main problem is the head if i remember right the exhaust port is raised on the indy's
These tti's should fit accord to TTI they lissted a a race heaer with a w-5 pattern on the exhaust
The TTi number you gave for you headers doesn't list the headers fitting TTI's but it is for a stock port location.
Re: 71 Demon TTI Headers Indy heads. Clearance problems [Re: 540challenger] #653633
03/29/10 12:10 PM
03/29/10 12:10 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Don't hesitate to call TTI. They have always been helpful when I called them.
