Moroso seat pressure tester will it work on RB mopar? #652812
03/27/10 06:21 PM
03/27/10 06:21 PM
IL . usa
cjs69mope Offline OP
IL . usa
Looking to buy a valve seat pressure tester .
Was wondering what type will work on mopar big block engines ? will moroso part number 62390 work with the shaft style roller rockers like harland sharp ? Does anybody have one of the on car style seat pressure testers? What brand works ? Thanks
1969 Dodge Charger 1969 Dodge Superbee
Re: Moroso seat pressure tester will it work on RB mopar? [Re: cjs69mope] #652813
03/27/10 11:29 PM
03/27/10 11:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I cant say if that one will work or not... but most
of those tester arent very accurate so without using
a particular tester on your springs when new, all you
can do is to see if your springs are close to one
another on pressure
Re: Moroso seat pressure tester will it work on RB mopar? [Re: cjs69mope] #652814
03/29/10 07:25 AM
03/29/10 07:25 AM
NEW YORK
MAXEDWEDGE Offline
MAXEDWEDGE  Offline
NEW YORK
I'M USEING THAT ONE ,IT WORKS WELL ENOUGH TO SEE IF ANY OF YOUR SPRINGS ARE GOING SOUTH.ITS A GOOD ESTIMATOR. MY BUDDY HAS THE LSM 100SLC MODEL WICH HE LIKES ALOT BETTER,HE SAY'S THE PRESSURES ARE MORE ACCURIT
