Best upgrades for 5.9L 2003 Ram for towing? #652638
03/27/10 12:58 PM
03/27/10 12:58 PM
Ridley Park, Pa.
69MOPE Offline OP
super gas
69MOPE  Offline OP
super gas
Ridley Park, Pa.
I will be completely tearing down the engine and transmission for rebuilding and blueprinting. What upgrades to camshaft, throttle body, cylinder heads (porting), PCM, and torque convertor do you recommend to improve towing without affecting emissions greatly. I already plan on a 3" exhaust after the cat and 4.10 gears for the Dana 60.
Re: Best upgrades for 5.9L 2003 Ram for towing? [Re: 69MOPE] #652639
03/27/10 03:49 PM
03/27/10 03:49 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
Starting from scratch? About the only thing I would reuse would be the block and engine dress, a 9.0 comp 408 with RHS heads, small cam like the mopar R/T or R/T +10, 2 barrel M1 intake with a 52-55mm TB and a set of the old Mopar/PPH try-Y headers would be a good towing motor.
About anything you do to a 360 mag to pick up HP/TQ is going to move the RPM range higher, with the 4" crank it will move the RPM range back down closer to what the stock 360 has but still have more power.
