Valve Retainers #652297
03/26/10 10:50 PM
03/26/10 10:50 PM
Canada
69 GTX Offline OP
69 GTX  Offline OP
Canada
I will be using a Comp cam XE284H with my Stealth heads, also Crane Gold 1.6 rockers this will give me a lift of .541/.544. Stealth says I need to upgrade to Comp valve retainers and locks, has anyone else done this upgrade and do you think it should be done?,also do you know the part # of Comp cams retainers to use with the 10 degree locks, Thanks
Re: Valve Retainers [Re: 69 GTX] #652298
03/26/10 10:55 PM
03/26/10 10:55 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
what springs are you using the retainers need to fit the springs...you can match up the locks to the retainers..
Tony
70 AARCuda Vitamin C
Re: Valve Retainers [Re: 70AARcuda] #652299
03/26/10 10:58 PM
03/26/10 10:58 PM
Canada
69 GTX Offline OP
69 GTX  Offline OP
Canada
These are the stock Stealth springs,single with damper,outer dia,1.550, inner dia,1.050
