Re: how do u adjust the idle
[Re: 62maxwgn]
#652094
03/26/10 06:36 PM
03/26/10 06:36 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
wow. that seems like a pain! the idle on the 6-packs wasn't all through the center carb?
<----------- never owned or worked on a 6-pak
**Photobucket sucks**
[Re: screamindriver]
#652100
03/27/10 08:01 PM
03/27/10 08:01 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
The wording is a little tricky on this thread but I don't think everyone is on the same page here...All the guy wants to do is turn the idle down on the center carb...Not try to pull lead plugs and mess with the fuel mixture on all three...
If you read his post he says the screw is under the carb.There is nothing on the center carb that has to do with idle that is under the anything. ![](/ubbthreads/images/graemlins/rolleyes.gif)
[Re: lokalik]
#652103
03/28/10 12:40 PM
03/28/10 12:40 PM
Posts: 316 Coolville, Ohio
Lew
Coolville, Ohio
boy the wording went south in a hurry on this one. to me to sounds like a curb idle question however, when ask in the same sentence about the screws under the carbs changes things. crub idle red or green circle as stated above. idle mixture under the carbs. buy the promax base plates they are worth the money.
Sounded like curb idle to me.
[Re: Lew]
#652104
03/28/10 01:50 PM
03/28/10 01:50 PM
Posts: 15,493 the boonies
aarcuda
the boonies
there is no idle screw on any of my carbs that are on the bottom like the OP posted. yes, there are mixture screws in the front and rear baseplates but he seems to be saying theres a throttle plate opening screw that comes up from the bottom- like the secondary idle adj screws on some 4 bbls- and mine dont have that
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
[Re: buildanother]
#652105
03/28/10 08:46 PM
03/28/10 08:46 PM
62maxwgn
Blair County,PA
I believe there is a fast idle screw in a squirrelly place down low, on passenger side of carb. The base idle screw should be in plain site on drivers side of carb, and I remember being able to turn it with my fingers with air cleaner in place. Even so, with air cleaner off, it is looking right at ya.
There are no screws on the passenger side of the carb.Only adjustment is the cam for the choke pull-off adjustment and that is done by bending the cam tab with a screw driver inserted into the slot on the lever.
