Could it really be my trans input shaft seal? GRRRR.
#651742
03/26/10 09:39 AM
03/26/10 09:39 AM
Posts: 3,336 Summit, NJ
whiplash
Summit, NJ
So I had my trans rebuilt by a local shop last year. I did the R&R on the trans. Drove the car for the year put around 3000 miles on it, no problems, shifts great. Put her to bed for the winter. Last week I fired her up after the winter, drove it for a day, checked the fluids, noticed I was wayyyyy low on tranny fluid, hmmmm, nothing much on the garage floor. Filled it up, ran it around the block, and then I saw it, a nice drip drip drip, from the front of the tranny, behind the access cover. Is the front seal the ONLY thing it could be? Is this a common thing with storing vehicles for the winter? Should I call the trans shop, even if I did the R&R? I hate the fact that a $7 part is going to cost me a day on my back....
- 67 coronet 4dr, 383/727/GVOD, blown, EFI, daily driver
- 230/238, 114°LSA cam, 1.6 rollers, 9:1 comp, 8 psi boost
- NEW BEST ET - 12.40@110mph...
Re: Could it really be my trans input shaft seal? GRRRR.
[Re: WILD BILL]
#651744
03/26/10 12:32 PM
03/26/10 12:32 PM
whiplash
Summit, NJ
They are a reputable shop so I would HOPE they did. The fact that it ran fine for the whole year without a drop and then suddenly leaked like a sieve leads me to beleive it is the seal but I just wan to ask the experts here before I call the shop.
[Re: Dodgem]
#651747
03/29/10 10:28 AM
03/29/10 10:28 AM
whiplash
Summit, NJ
Yes, deep pan. No it was not overfilled. If anything it may have been a little low. Yes, it leaks as long as the engine is running.
[Re: 69Cuda340S]
#651749
03/29/10 03:47 PM
03/29/10 03:47 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
As teh guys mentioned, check the easy things first. However, I had a failure once wherein the trans started leaking like crazy from the front, and it happened in the span of about 10-15 miles. It was fine for 4-5 years, then one day - not fine. Pump bushing was shot. Don't know if that was the failure mode or a symptom, but a new converter (old one had a few starter teeth missing), new bushing and seal fixed it.
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: 69Cuda340S]
#651751
03/30/10 04:04 PM
03/30/10 04:04 PM
whiplash
Summit, NJ
interesting things about the converter. It is a PTC 9.5" the guys down there are pretty good, so I would hope the converter is true, BUT.....
When I pull it apart, will there be an abnormal wear mark and where?
