I have not used that product but something like it called AlClad, a lacquer with ground aluminum in it that you airbrush over a glossy black surface and it gives you a chrome finish far superior in gloss to any spraycan junk sold at the stores. If you use too much, it will dull down to a semi-gloss looking aluminum which is what I used to refinish 68 barracuda instrument clusters. I used a mirror finish on the bezels, and for the dash aluminum looking inserts I over applied it for an aluminum semi gloss, one caveat to using it tho, it will rub off if you touch it a lot, hands off and no cleaning chemicals or you'll be refinishing it. Clear coats only dull the shine but will protect it.
