Re: sleeve a 318 and bore to 340
[Re: alpha727]
#650768
03/25/10 07:53 AM
03/25/10 07:53 AM
Posts: 650 Kansas
racincuda
Kansas
Havent priced sleeves lately but it used to be around $100 per hole + boring. You could probably talk me out of my 69 340 block for less than that, or quite a few others I would guess. But hey if money is no object then go for it ! oh and pick up a stroker kit to go with it as well ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Scamp408]
#650771
03/25/10 11:18 AM
03/25/10 11:18 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I'm sure it could be done, but is the cost worth it? average cost a few years ago for sleeves was $100 a hole...not sure if that's gone up or down in the past year or so, but if you figure that, plus the cost to machine the sleeves afterwards...you're probably looking at $1,000-$1200 to turn a 318 into a 340. how much would a 340 block run you at the swap meets, online, etc.?
**Photobucket sucks**
[Re: 70Cuda383]
#650772
03/25/10 11:35 AM
03/25/10 11:35 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
You really need to sonic test it first. It may be able to be bored to 4" (360 size...), but you have to have a little meat to give the sleeve some stability. I'd be concerned about leak posibilities by doing that on all 8. A std 318 type wouldnt concern me. But removing that much wall structure does.
[Re: rebel]
#650776
03/25/10 02:04 PM
03/25/10 02:04 PM
Posts: 282 Stockholm,SWEDEN
The Nutcracker
Stockholm,SWEDEN
My 340 was sleeved on al 8 when i bought it, Makes stable cylinderwalls. I like the idea of a sleeved 318 stroker, tell people its a stock 318!
-70 Cuda,-65 Valiant,-66 Valiant,-62 FED
[Re: domingo]
#650779
03/25/10 11:39 PM
03/25/10 11:39 PM
Posts: 1,745 Maryland
340_Dart
Maryland
buy a race block. They are not that expensive.
Even if you can get a 340 out of it, you still won't have thicker main journals, or 4-bolt mains like most race blocks have or can be fitted with.
[Re: emarine01]
#650781
03/26/10 11:39 AM
03/26/10 11:39 AM
moper
Columbia, CT
I don't know what the industry standard is for remaining wall thickness for dry sleeves < how far you can bore to fit the sleeve> I don't think the sleeve is structurally strong by its self, the sleeves have some benefit in ware from the rings vs the cast iron block but I don't think its a cost effective way to increase bore
That was what I am thinking... Sleeving a block with the normal type of sleeves will leave material behind to help stabilize things. Removing all the original cylinder material I think would not support the sleeve or deck well enough. Never mind the cost/return issue.
