lower rad hose #650595
03/24/10 09:33 PM
03/24/10 09:33 PM
Ontario. Canada
hemidere Offline OP
hemidere  Offline OP
Ontario. Canada
Looking for a part number for a lower radiator hose to go from 1 3/4" at the engine to 1 1/2" on the radiator. Using the original B-body 22" rad recored to cool a 440. Any brand of hose part number will do as a cross reference. Any help would be greatly appreciated...
Re: lower rad hose [Re: hemidere] #650596
03/24/10 09:35 PM
03/24/10 09:35 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
what car? What year rad? Stock 440 water houseing?
Re: lower rad hose [Re: Dougsmopars] #650597
03/24/10 10:29 PM
03/24/10 10:29 PM
IN
ahy Offline
ahy  Offline
IN
It sounds like a stock hose. I bet you can go to NAPA online and pick it out. That worked for me on a different application (1970). A couple days to order and you've got it. If you are really in a hurry, the universal ribbed hoses are usually available in 1 1/2 x 1 3/4 and in stock.
Re: lower rad hose [Re: Dougsmopars] #650598
03/25/10 08:12 AM
03/25/10 08:12 AM
Ontario. Canada
hemidere Offline OP
hemidere  Offline OP
Ontario. Canada
67 Belvedere with the original 22" rad and stock pump housing...
Re: lower rad hose [Re: hemidere] #650599
03/25/10 09:44 AM
03/25/10 09:44 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
try either one
gates 20558 or 20663
