4150 carb guru's......pouring venturi's!!! #650437
03/24/10 07:53 PM
03/24/10 07:53 PM
Lapeer, MI.
todd440 Offline OP
todd440  Offline OP
Lapeer, MI.
I've got an 4150 that was older, but new. I put a full holley kit in it, just to make sure the gaskets were perfect. It's dumping fuel out the boosters. Not a drip, but a steading gush. I've changed needle and seat 3 times, no luck. It's just the secondary. I even changed the bowl, just to make sure it wasn't a float problem. It's a 440 with a stock replacement carter pump, not a high pressure unit. Fuel does not come out the vent. Any ideas?
Re: 4150 carb guru's......pouring venturi's!!! [Re: todd440] #650438
03/24/10 07:55 PM
03/24/10 07:55 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
sounds like a float problem.
Coming soon!!!!
Re: 4150 carb guru's......pouring venturi's!!! [Re: Mr.Yuck] #650439
03/24/10 07:58 PM
03/24/10 07:58 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Never had one do it in the secondaries but in the primaries it was a blown power valve...Now I just block them-off...
Re: 4150 carb guru's......pouring venturi's!!! [Re: Mr.Yuck] #650440
03/24/10 09:13 PM
03/24/10 09:13 PM
Lapeer, MI.
todd440 Offline OP
todd440  Offline OP
Lapeer, MI.
It's weird. No power valve, and I've ruled out the float by changing the bowl. If it were a pressure issue, I'd think the front would be leaking as well.
Re: 4150 carb guru's......pouring venturi's!!! [Re: todd440] #650441
03/24/10 09:19 PM
03/24/10 09:19 PM
okla.
sam64 Offline
sam64  Offline
okla.
is fuel running out at float level check hole with plug removed?
Re: 4150 carb guru's......pouring venturi's!!! [Re: sam64] #650442
03/24/10 09:30 PM
03/24/10 09:30 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
throw it in the trash and replace it with an Edelbrock 750m
Don't be the exception.
Re: 4150 carb guru's......pouring venturi's!!! [Re: Supercuda] #650443
03/24/10 10:15 PM
03/24/10 10:15 PM
Columbia Station, Ohio
69RTSE Offline
69RTSE  Offline
You seem pretty sure it's not the float. There is a plug instead of the rear power valve, right? Wrong gaskets maybe? Can you swap the rear metering block to the front and see if the problem moves?
Re: 4150 carb guru's......pouring venturi's!!! [Re: Supercuda] #650444
03/24/10 10:21 PM
03/24/10 10:21 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
if you want the car to slow down
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 4150 carb guru's......pouring venturi's!!! [Re: 69RTSE] #650445
03/25/10 01:20 AM
03/25/10 01:20 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
If the float has a hole in it and is sunk, nothing you do will fix it short of replacing the float with a good one.
I rebuilt a 750 Vac sec recently that had sat for a number of years, float sunk and it spewed fuel everywhere. Replaced the float, runs great.
Re: 4150 carb guru's......pouring venturi's!!! [Re: RobX4406] #650446
03/27/10 06:23 AM
03/27/10 06:23 AM
Lapeer, MI.
todd440 Offline OP
todd440  Offline OP
Lapeer, MI.
Well, I ended up changing the rear bowl and metering block, same problem. I hooked up a pressure gauge, only to find 11 psi out of the stock carter pump. This is the stock replacement style pump. I've never seen one that high.
Re: 4150 carb guru's......pouring venturi's!!! [Re: todd440] #650447
03/27/10 08:58 AM
03/27/10 08:58 AM
Which one?
Re: 4150 carb guru's......pouring venturi's!!! [Re: RapidRobert] #650448
03/27/10 09:45 AM
03/27/10 09:45 AM
Lapeer, MI.
todd440 Offline OP
todd440  Offline OP
Lapeer, MI.
It's the m4845, which is a muscle car replacement for 70-71 cars, rated at 5.5 psi, or so they say.
Re: 4150 carb guru's......pouring venturi's!!! [Re: todd440] #650449
03/27/10 10:00 AM
03/27/10 10:00 AM
From what I understand the spring stiffness (plus the passage dia's) controls the psi and the lobe reloads (compresses the spring) so I'm wondering if an assembly line guy accidently (or on purpose ) put the wrong spring in there as it was going down the line
Re: 4150 carb guru's......pouring venturi's!!! [Re: RapidRobert] #650450
03/27/10 11:26 AM
03/27/10 11:26 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I've had problems with that fuel pump in the past, mine pumped out 10+ psi & blew past the needle/seats, get you a different pump.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: 4150 carb guru's......pouring venturi's!!! [Re: joedust451] #650451
03/27/10 05:12 PM
03/27/10 05:12 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
if your needle isn't seating properly you can have this problem.
i know with my carb the jet extenders can cause interference with the floats also.
perception is 90% of reality
Re: 4150 carb guru's......pouring venturi's!!! [Re: Mr T2U] #650452
03/27/10 07:18 PM
03/27/10 07:18 PM
Lapeer, MI.
todd440 Offline OP
todd440  Offline OP
Lapeer, MI.
I just switched to a new carter M4589, stock style pump, and the pressure is 6 psi. All is well.
