65 coronet crossmember newer tranny #650238
03/24/10 04:18 PM
03/24/10 04:18 PM
midwest
afx man Offline OP
afx man  Offline OP
midwest
I have a 65 coronet and it came with no crossmember and I plan to install a 4 speed. The transmissions I have are a 67 and 70 hemi 4 speed (18 spline). I have been told the transmission mount is in a different place on the earlier transmissions. Will I need the 65 auto or 65 manual crossmember?
Re: 65 coronet crossmember newer tranny [Re: afx man] #650239
03/24/10 04:23 PM
03/24/10 04:23 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
65 auto x member and the conversion mount from schumacher or brewer
Re: 65 coronet crossmember newer tranny [Re: prochargedhemi] #650240
03/24/10 04:55 PM
03/24/10 04:55 PM
Yep, I put a later transmission in my '63 B-body Using the Schumacher (imperial services) mount and everything bolted up perfectly!
