converter stall and performance #649913
03/24/10 11:10 AM
03/24/10 11:10 AM
michigan
challenged448 Offline OP
michigan
I am wondering how much of a performance gain I would get from changing my converter stall speed from 6000 present to 5200-5400.I shift at 6500 and go through the traps at 7000. The car is a 67 cuda 540 pump gas motor,727,373,28" tires,700hp. Best so far 9.88 at 135.9 with a 1.37 60', footbrake.
Re: converter stall and performance [Re: challenged448] #649914
03/24/10 11:55 AM
03/24/10 11:55 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You want the stall at or a little above your peak
torque RPM and I have always heard it should be about
1300 to 1500 below the shift point.... right now
you dont spend much time with the converter locked
up so in your case I would believe it would help
by lowering the stall.... BUT what is peak torque
at... you might be shifting too early..... JMO
Re: converter stall and performance [Re: MR_P_BODY] #649915
03/24/10 03:52 PM
03/24/10 03:52 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I myself like a loose converter. I don't think you would see any gain and may even lose a little.
