Re: Suggestions for widening sbp steel wheels
[Re: Kern Dog]
#649777
03/24/10 07:43 PM
03/24/10 07:43 PM
Posts: 1,014 Midwestern Indiana
duster2
Midwestern Indiana
The correct way to do the wheels is to find the correct size rim shell. That would be one that is 12.25 on the inside. They can be made the standard way with ( probably ) about 4 1/2 inch backspace and use a 1/4 billet spacer ( because the way the rim shell is made ) or reverse the rim shell and make it a 4 inch backspace. That is the way member Mopar155 wheels were made , his car appeared in Mopar Muscle this month. Those were my wheels. I am in the process of getting two pairs of 15 x 8 steel wheels made at this time , reversed with a 4 inch backspace. I just took my buddy 14 cores to start making small bolt steels. The Wheel Guy Frank
[Re: duster2]
#649778
03/24/10 09:38 PM
03/24/10 09:38 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Yep, they are a common part and not very pricey...you can get them in a bunch of assorted 15" sizes if you wanted to go wider. I just shipped about 14 pallets of them actually...
The pallet on the lower left are 15" x 8" in chrome with the large drop to use 14" centers actually
[Re: alpha727]
#649780
03/25/10 07:53 AM
03/25/10 07:53 AM
Posts: 708 Mechanic Falls, Maine
4BBodies
mopar addict
mopar addict
If you have access to a lathe, you could make a jig out of a chunk of 1/2" aluminum that the lip of the rim (whatever diameter) fits in. Then, all you would need is something to bolt the center to, centered, of course. It could be mounted at 3", 4", wherever you want the back spacing. You could even have different "bolt patterned" plates that bolt to the riser. I can't see where it would be that big a deal, finding center is easy with a lathe. Then, when everything is in place, weld it. A friend made something similar for his Indian bike, for lacing the spokes. It was a copy of what the factory used. All 4 wheels spun true, it worked great!
[Re: OzHemi]
#649781
03/25/10 08:07 AM
03/25/10 08:07 AM
Posts: 309 Hampden, Maine
Procommuter
super street
super street
Hampden, Maine
Oz, Where can I get chrome 15 x 8 rim shells?
Wes
73 Barracuda 440 EFI 4 speed, 144.85 MPH LTA A/FSS Record Holder.
[Re: Procommuter]
#649782
03/25/10 10:45 AM
03/25/10 10:45 AM
OzHemi
Garden Grove, CA
I get mine from Intero/Carlise....not sure if they will sell to the public or not, (especially in small quantities) but always worth a shot... (Carlise owns Cragar as well..) I usually buy 15 - 25 pallets worth of outers and a few of centers at a time.... Chrome stuff is slow with them since they have changed around thier production setup here.
[Re: OzHemi]
#649783
03/25/10 03:51 PM
03/25/10 03:51 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
The problem with welding in 3/16" spacers is the curvature, and in making sure your wheel center is truly centered. However, if you get a proper-size hoop for your center, I truly believe that widening a wheel is within reach of a skilled DIY person. A drum/rotor and spindle make a cheap jig to use, a cheap dial indicator is sufficient for measuring. After that it's simply limited by your skill. http://www.fordmuscle.com/archives/2006/02/Steelies/index.phphttp://forums.turbobricks.com/showthread.php?t=92573
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
