Re: Rebuilt 400 should I have oil pressure when cranking?
[Re: wh23g3g]
#649109
03/23/10 04:54 PM
03/23/10 04:54 PM
Posts: 15,487 Florida
scratchnfotraction
I pulled the plugs on my 440 thats from a MH and had been sitting a couple yrs after a little bit of spinning I was getting a reading on the stock gauge as it spun over poped the plugs in and fired it off,fired right up and did not clatter like most will do after sitting I had done the spinning and no plugs a couple difftimes/days before ready to fire it off you may or may not see it with a mech gauge oil duz not have to reach all the way to mech guage to read I have seen them with air pockets on the sb truck never had any troble with it I say pull the plugs,spray WD40 in the cyls,spin it over a few times with short burst of the key 30-45 seconds at a time,should be ready if you have already primed it with a drill also good luck on the fire up
[Re: wh23g3g]
#649112
03/23/10 07:24 PM
03/23/10 07:24 PM
RapidRobert
I've changed oil/filter and cranked the eng w the ECU disabled until the psi came up which sometimes takes quite a few seconds. With all the turning over you have done so far I would consider taking off the intake and regooping the lobes/lifter bottoms.
[Re: MoparforLife]
#649114
03/23/10 09:53 PM
03/23/10 09:53 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
I'm also against cranking without fire. As already mentioned, the cam lobes but also many parts of the engine are not lubed during cranking. The piston pins, rings, cylinder walls and usually the cam lobes are not lubed during cranking.
[Re: wh23g3g]
#649117
03/23/10 10:57 PM
03/23/10 10:57 PM
RapidRobert
So should I re-prime with the drill and just fire it up?
When you were preoiling if you stopped at the 2 spots to send oil to the valvetrain then it oil primed everywhere. The problem is the cranking has wiped too much of the cam lube off of the lobes. Myself I would pull the intake and regoop the cam. I'd pull the stat, jack up the front of the car (air pockets),fan in front of rad, 1 helper to add trans fluid, 1 helper to man the light/adj dist, 1 helper to check for leaks (fuel mainly) up top, 1 helper underneath to check for oil/fluid leaks, carb bowls filled/squirting, dist producing sparks, timing @ 10BTDC w reluctor dead on the magnet slot (fires at 8-9 BTDC) set carb throttle screw for ~2500rpm, you in drivers seat to monitor tach/gauges and to shout orders, remove the inner valve springs, gun the throttle many time during the 20-30 minute breakin. read "break in secrets" a 5 minute read www.mototuneusa.com EDIT I reread that it's been several month since preoiling, yes I'd preoil again (and the above). you have too much invested to overlook/take shortcuts at this critical point
