5 inch 65 - 67 hemi scoops #648929
03/23/10 11:40 AM
03/23/10 11:40 AM
Georgia
66coronet Offline OP
Georgia
Any pictures, either on the car or off, of the 5 inch or oversized 65 - 67 hemi scoops on those model B bodies? I have only seen a hand full of these scoops mounted on a car. Just curious how they look on cars good or bad.
Re: 5 inch 65 - 67 hemi scoops [Re: 66coronet] #648930
03/23/10 01:59 PM
03/23/10 01:59 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Which year scoop do you want ?... 64-5 or 66-7 ??
They are diff.
Re: 5 inch 65 - 67 hemi scoops [Re: dOoC] #648931
03/23/10 03:50 PM
03/23/10 03:50 PM
Georgia
Georgia
They are close enough in design that it doesnt really matter to me. Mainly just wanted to see as many pics of the additional height scoops as I could.
Re: 5 inch 65 - 67 hemi scoops [Re: 66coronet] #648932
03/24/10 12:48 AM
03/24/10 12:48 AM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
I took a standard size RO scoop and had 1 1/2 added all the way around. As soon as it gets back from paint and I mount it to hood,I will post pics of it. It measures 4 1/2 in the front. I thought your car had a 5 inch scoop?
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: 5 inch 65 - 67 hemi scoops [Re: 67HEMI] #648933
03/24/10 08:44 AM
03/24/10 08:44 AM
Georgia
Georgia
No, its the standard VFN scoop. It is in between most sizes for some reason. I believe it measured 3 1/2 at the opening. The weird deal with my scoop is the taper to the back. It does not taper down as much as most that I have seen. Which has worked well for me up until now. I need a little more room. I need to talk to a good fiberglass guy and see if they could do something similar to what you describe with mine.
