Any hope for 273 Commando heads? #648710
03/23/10 03:22 AM
03/23/10 03:22 AM
Pyeongtaek, South Korea
69HemiGTX Online content OP
69HemiGTX  Online Content OP
I have a pair of 273 Commando heads I scored off an engine with a broken block and crank I found abandoned in a junk yard. A four-speed at that! Anyways, how far can they be ported? What do y'all think the max cubes they can support is? I have the intake, too, but like an idiot, I sold the rockers a long time ago. I have no idea what casting number the heads are. These are deffinitely Commando parts - closed chambers, adjustable rockers, and an iron single plane intake.
OIF V and OEF X veteran and proud of it!
Re: Any hope for 273 Commando heads? [Re: 69HemiGTX] #648711
03/23/10 04:27 AM
03/23/10 04:27 AM
Utah
topbrent Offline
topbrent  Offline
Utah
Thanks for your military efforts.
Focus on staying safe as you serve.
Regarding 273 stuff....No hope at all...My
You didn't say what your HP goals are.
Put all on the 273 stuff on the shelf and build a 360 or stroked 360. If if came with the nice 273 Commando valve covers, use them on your new build. You should be able to find a 360 core for a couple hundred or less.
Before you sink any $$$ into those heads, take a look at the Indy/RHS iron heads.
It is hard to go wrong starting with a 360 or 408.
It is very hard to recommend building a 273.
Building a 360 based motor = Parts are easier to obtain and the HP is automatically there.
Consider that 408" = 135 extra cubic inches at the same weight penalty.
Good builds to consider:
Brian @ IMM engines
https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Board=Racer&Number=5791384
Drag Strip results: https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Board=Racer&Number=5861879
Jesse Lackman
https://board.moparts.org/ubbthreads/show...rue#Post4070225
Qwkmopardan has some awesome budget builds:
https://board.moparts.org/ubbthreads/showflat.php?Number=5455580&page=0
Re: Any hope for 273 Commando heads? [Re: 69HemiGTX] #648712
03/23/10 11:38 AM
03/23/10 11:38 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The 273 used the same heads for the commandos and non commandos untill the commando went away in 68 then they used the 318 open chamber head. Absolutly nothing special about a head from a commando VS a head from a 2bl motor.
As for how many cubes they can support, well that depends on how many RPM you want to turn. The 273 D-dart engines would go 7000 so in a 360 that would equal about 5300 rpm. The 360 will unshroud the valves a little more so might go 5500, max ported with big valves they can mabey make 400hp on a 360.
For casting numbers they are probably a 315 or 920 depending on year. 920 was the 67 only head.
Re: Any hope for 273 Commando heads? [Re: HotRodDave] #648713
03/23/10 12:18 PM
03/23/10 12:18 PM
sweden
sshemi Offline
sshemi  Offline
sweden
do you have any close up pics of the intake?
Re: Any hope for 273 Commando heads? [Re: HotRodDave] #648714
03/23/10 12:52 PM
03/23/10 12:52 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
and if they're 315 heads, they're probably the funky oddball intake bolt angle used in 64-65 or 64-66 IIRC.
port volume wise, for a performance app, I wouldn't go above a 318 for displacement. for a torque app, they'd be nice on a stock long block 360 with a small, fast rate cam (voodoo 60401 maybe)
2017 Grand Cherokee Overland
Re: Any hope for 273 Commando heads? [Re: patrick] #648715
03/23/10 02:19 PM
03/23/10 02:19 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
The 273 Commando motors were really cool back in the day. I remember a Hot Rod cover(think i still have it!) with a 273 commando Barracuda G/stock or something like that, that was a record holder at the time. I had one in a 65 Barracuda..and it was a great engine. But you really need a 4 speed to keep the revs up. Todays world is so different tho, actually the 340 changed everything. Now you can get cheap 360s that can make HP with any of the SB from chevy or ford.
Re: Any hope for 273 Commando heads? [Re: patrick] #648716
03/23/10 02:50 PM
03/23/10 02:50 PM
The general consensus here is what I was thinking. The ports just look too small for anything north of 320" in a performance application. As far as RPM, peak would be around 6800-7000, with the bottom being near 3000. Sorry, I don't have any pics, and I can't take any right now (8500 miles from home ). After doing more research, RHS X heads would be the minimum I would use, albiet with some porting. Of course, W2s would be the optimum choice, but I'm not a fan of the pushrod angles involved. The engine rules below just got my mind working. These are for dirt modifieds:
Devil's Bowl Speedway USA Modifieds
POWER TRAIN:
A) Can use any American-made engine with iron heads and block.
1. Rear of engine (bell housing flange) must be mounted at least 72” forward of the centerline of the rear axle. Engine offset must be within 2” of the centerline of the front frame crossmember. The minimum engine height is 11” from the ground to the front center of the crankshaft.
2. Cooling systems can be modified as long as radiator and/or coolers do not extend above the interior. Overflow tubes must be directed toward the ground inside the frame rails.
3. No total dry sump oiling systems allowed. The wet systems must be operable.
4. Fuel can be gasoline or alcohol. No performance-enhancing fuel additives of any kind. Use of any such additive will subject the driver to a $1,500 fine, four weeks suspension from races for the driver and car, and loss of all points for the year.
5. A single two-barrel or four-barrel naturally-aspirated carburetor is allowed. Fuel injection, electrical fuel pumps, and/or magnetos are not allowed.
6. Engines used in competition must be capable of use in a conventional passenger car without alterations. Motor mounts, castings, and/or fittings cannot be altered. Machine work on the outside of the engine, front of camshaft, or rear of camshaft is not allowed.
7. The heads must be in stock configuration. Valve degree cannot deviate more than 1 degree from stock. No raised runners.
Enid Speedway Modifieds
23. ENGINE SPECIFICATIONS: Any American make engine allowed. Iron heads and blocks. Steel oil pan only.
All engines must be able to be used in conventional passenger cars without alterations. Engine mounts cannot be
removed or altered. Castings and fittings must not be changed. No machine work on outside of engine. Wet oiling
systems only.
Obviously, roller cams and unlimited cubes are the norm, but traction is limited by small, somewhat hard spec tires.
Re: Any hope for 273 Commando heads? [Re: 69HemiGTX] #648717
03/23/10 03:02 PM
03/23/10 03:02 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Well I too hate the PR angle of the W2 but they would be the best choice, you have to make up for the lost lift with a bigger cam or higher ratio rockers. Guys out there turn 8000 with W style rocker set ups all the time. By the way a higher ratio rocker helps the PR geometry in a SB. Run the biggest bore you can to deshroud the valves, what stroke you run will just be determined by the gear you want to run (shorter stroke=more RPM=lower gear ratio and vise aversa). I would get the heads angle milled to 17*
If you want to run the RHS heads you will make less power, my theory is always build as much HP as you can and then figure out how to use it.
Re: Any hope for 273 Commando heads? [Re: HotRodDave] #648718
03/23/10 03:34 PM
03/23/10 03:34 PM
I like the way you think. I always say that you can drive a fast car slow, but you can't drive a slow car fast. I was thinking along the lines of a P4876673AD siamese 48-degree R3 block, W2 heads, a solid roller and offset lifters, and a custom billet steel crank on alcohol. A 4.100 bore and a 3.750 crank yeilds 397"
Re: Any hope for 273 Commando heads? [Re: 69HemiGTX] #648719
03/23/10 03:40 PM
03/23/10 03:40 PM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
is a big block out of the question?????
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: Any hope for 273 Commando heads? [Re: StripeHOG] #648720
03/23/10 11:39 PM
03/23/10 11:39 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
A BB will add a lot of weight over the front where it is not needed.
Re: Any hope for 273 Commando heads? [Re: HotRodDave] #648721
03/24/10 08:04 AM
03/24/10 08:04 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
is a 48 degree block legal, since it deviated from a stock production application?
for that powerband, I'd think about maybe a stock stroke 400 with some iron indy SR's....
Re: Any hope for 273 Commando heads? [Re: StripeHOG] #648722
03/24/10 08:32 AM
03/24/10 08:32 AM
A big block would affect the CG, roll centers, roll axis, F/R percentages, and crossweights too much. A 400 weighs about 80 pounds more than a 360. If it didn't, a 400 would be perfect.
The rules don't specify that the block has to have been a production part. They just say they have to be iron. There are plenty of Bowtie, World, and SVO blocks out there. I've seen a few R3s, but sadly, they were the only few Mopars in a sea of Chevy garbage with some Fords sprinkled in. I have no idea if they were 48 degree blocks, but if I was spending the coin, I wouldn't choose anything else.
Re: Any hope for 273 Commando heads? [Re: 69HemiGTX] #648723
03/24/10 12:07 PM
03/24/10 12:07 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
so are all the chevy guys limited to 23 degree heads (what a stock Gen1 SBC is)?
what kind of HP are the top guys in the class making?
is there a CID limit?
Re: Any hope for 273 Commando heads? [Re: patrick] #648724
03/24/10 01:55 PM
03/24/10 01:55 PM
Yes, they have to run 23 degree heads.
I'm not sure about most guys, but here's an example of what's out there: 620HP/590TQ 415 Chevy Hard to beat for $10K.
No CI limit, but like I said, the tires are not the best to work with. That's why the car above has such an agressive attitude. You really need to manipulate the suspension geometry to plant the car to the track. If you want to see what I mean, watch this video. Can you say pinion angle?
