Re: '74 360 oil filter plate & main bolts for eng build
[Re: Locomotion]
#648025
03/22/10 05:39 PM
03/22/10 05:39 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
I am not exactly sure what your doing as an adapter..for the filter.. your talking about the the standard hardware for the filter mechanism...(stock)? or something other than stock..? If you need a large gasket you can rob one off of a $3.00 filter..the rubber ones imho work better than the cork. cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: DusterW2]
#648026
03/22/10 05:58 PM
03/22/10 05:58 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Get the adapter fitting and plate from a junk yard motor.
The filter to block adapter doesnt require a gasket when used without a 90* adapter.
Get Mopar Performance part # P5249320 gasket kit.,
RIP Monte Smith
[Re: Locomotion]
#648027
03/22/10 06:48 PM
03/22/10 06:48 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
The straight-on oil filter assembly takes one gasket and the plate and double-threaded filter fitting are easily found used.
All 340 and 360 main bolts are the same. I'm pretty sure that 318 and 273 bolts are shorter because the caps are not as beefy.
Go into your local dodge dealer and get the plate whick is 8 hole vs 4, and the bolt from a magnum 318 or 360 use say a 2001.
Kasey
[Re: Moparnut426]
#648028
03/22/10 07:00 PM
03/22/10 07:00 PM
Posts: 1,090 north cakalaky
instigator
north cakalaky
should I pull off my 4- hole plate and drill it out to 8 holes....never had oil pressure issues with it before, engine is on stand, so should be really easy.
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
[Re: DusterW2]
#648029
03/22/10 09:22 PM
03/22/10 09:22 PM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
John, let me know if you need the plate, fitting and main bolts I can hook you up.
Mike Gray
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
