Re: spindles fit A, B and E body??? Is that right?
[Re: AndyF]
#647769
03/23/10 03:54 PM
03/23/10 03:54 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
I doubt the seller knows more. He lists those as fitting a Toad runner. Quote:
Spindles fit B & E Body Style Chrysler, dodge, plymouth(Cordoba, Dart Polara, charger magnum, Savoy, Belvedere, Satellite, GTX, Toad runner, Regent Sebring, Sport Fury, Suburban.
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: AndyF]
#647770
03/23/10 09:23 PM
03/23/10 09:23 PM
Posts: 15,493 the boonies
aarcuda
the boonies
My guess is that the seller is wrong. As far as I know, nobody is reproducing the small bearing knuckle. I could be wrong of course. Maybe the seller actually knows more about his parts than I do!
Well I should know in a few days..... i bet you are all right but I hope youre all wrong.
I will post the findings.
On a good not, I went to buy new rotors for the cuda. O'reillys had them for $177 each
Advance auto had them for $225 each
Autozone had them for $77 each So I bought them expecting them to be the wrong ones. BUT i picked them up today and while they are a one piece rotor/hub, they are the small bearing rotor and look like they will work. i'll take a better look at them tomorrow.
The oreilly and advance rotors were Wagners while the autozone was a duralast (but it looks to be the same thickness as my originals...)
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
[Re: aarcuda]
#647772
03/26/10 03:38 PM
03/26/10 03:38 PM
aarcuda
the boonies
Well the rotors showed up today and guess what, THEY ARE THE FREAKING LARGER BEARING SPINDLES
man, nothing ticks me off more than ASKING A STRAIGHT FORWARD question and getting a wrong answer- especially since I could have bought some others from Steves Musclecar parts at the beginning of the week and had them here by now to go on the car tomorrow.
but no, i took a chance and got the shaft. now the car sits until next week.
dagnabbit
