Re: How to change a Yolk on a Diff?
[Re: 440charger70]
#646866
03/21/10 12:37 PM
03/21/10 12:37 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
I'm looking at a diff with a small yolk. I need a big yolk, but this is a good deal. How difficult is it to change out a yolk? Does it bolt in or require more disassembly of the diff?
What kinda chickens do you have?
A yolk is the yellow part of an egg. A yoke is what is on a rear...No it's no big deal but if it's a crushed sleeve,some say you should replace it when changing yoke's...I got away with just changing it before. Make sure it's torqued back on so it doesn't loosen up later...
[Re: 440charger70]
#646872
03/21/10 06:24 PM
03/21/10 06:24 PM
Posts: 25,852 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Normally, when removing a 489 yoke for a seal replacement, etc. one can simply mark the relationship of the pinion threads with the nut so that the nut can be tightened to its original position thus retaining the original bearing preload.
But the replacement yoke might have a different dimension from the nut/washer surface to the rear of the yoke so the pinion/nut marking doesn't guarantee the same preload; but I'd wager that the dimension difference, if any, is so slight as to be negligible. I'd just mark the pinion thread and nut with a center punch, change the yoke and tighten the nut to that mark with some red Loctite.
