Re: Painting polished aluminum wheels
[Re: 340SHORTY]
#64668
05/27/08 05:14 PM
05/27/08 05:14 PM
Posts: 9,116 Falconer, NY
KatFysh
Falconer, NY
I am not positive if they have a clearcoat on them from the factory or not. I was thinking about blasting but I'd be afraid of having them end up getting pitted. By sanding, do you mean just scuffing? These are thems.. http://cas07.businessflow.ms/3.9.6/media...e1b1&size=1
[Re: KatFysh]
#64669
05/27/08 08:08 PM
05/27/08 08:08 PM
Posts: 638 South East VA
Joel71
South East VA
I've been wanting to put black wheels on my Ram. I've been watching wheels on that auction site. Anyways, if I was to purchase a set of used stock polished aluminum wheels, what would I need to do to prep the wheel for either paint or powdercoat??
If you're going to paint them and the are clear coated, just sand and paint. If they're bare aluminum, sand, epoxy prime, and paint. I'd use the epoxy primer either way just for added strength and adhesion.
[Re: Joel71]
#64670
05/27/08 08:16 PM
05/27/08 08:16 PM
KatFysh
Falconer, NY
Okay, thank you Joel and mmissile... What about powdercoating? Would that be an option on these wheels..
When you decide to quit, THAT is the moment when you would've succeeded..
[Re: KatFysh]
#64671
05/27/08 08:29 PM
05/27/08 08:29 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
BEAD blast,,, not sand blast,, bead is much finer.. powder coating will outlast any/all painting...
I am truckless..
