Braille Lightweight battery #646511
03/20/10 09:52 PM
03/20/10 09:52 PM
Ripley
BryanRad Offline OP
BryanRad  Offline OP
Ripley
Has anyone here tried the subject battery and if so how did it do?
Re: Braille Lightweight battery [Re: BryanRad] #646512
03/21/10 02:50 AM
03/21/10 02:50 AM
Wisconsin USA
Albert Lee Offline
Albert Lee  Offline
Wisconsin USA
I have two of them in my small block stock eliminator car - one in front and another in the trunk. They worked just fine and I've had them for the last two years. I always top them off with an automatic, decreasing rate charger after each run.
They make several different sizes - mine were the 17 pounders.
Re: Braille Lightweight battery [Re: Albert Lee] #646513
03/21/10 08:43 AM
03/21/10 08:43 AM
Ripley
BryanRad Offline OP
BryanRad  Offline OP
Ripley
I was looking at the 147-B3121 its 21 lbs and they are very compact. The cca at 32 is 742, which if they are what they advertise it should crank over my 604 with no problem. I think the idea of it being light and compact.
