66 aBODY FRT SUSPENSION Q? #646420
03/20/10 07:46 PM
03/20/10 07:46 PM
Gateway to the West.
hemi_harvester Offline OP
Is the front drag link different /6 and V8
Also I want to put 73 upper and lower arms on it
Can I use B-body drum spindle? if NO them are late A and F body the same?
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: 66 aBODY FRT SUSPENSION Q? [Re: hemi_harvester] #646421
03/20/10 08:44 PM
03/20/10 08:44 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
centerlink is the same for /6 and V8 in '66, you can use '73-up a-body lower and upper control arm on it and you will have to if you want to use a B-body drum spindle since you will need the big upper ball joint that was used on '73-up A-bodies. You will also need the '73-up A-body lower and upper ball joints
