Stupid 727 question? #64641
05/27/08 04:27 PM
05/27/08 04:27 PM
Southaven, MS
BossRide Offline OP
BossRide  Offline OP
Southaven, MS
Is there a visual difference in a small block 727 and a bb? Or an early 727 and a later one that will fit a 70's LA 360? A buddy has one that is one the back of an old Hemi out of a hot rod, is there a way to know if it will work behind my 360?
The Blue Goose
My instagram: Bossride
Re: Stupid 727 question? [Re: BossRide] #64642
05/27/08 05:07 PM
05/27/08 05:07 PM
Andrewh Offline
Andrewh  Offline
you will have to measure to find the right one.
As for one from an old hemi, depends on how old, and if it is original or not.
The 392, no. 331 and earlier, I think might work.
If it is original though, it leads to a couple of other problems. You cannot use a newer torque converter on it, it will be a ball and trunion drive shaft, and one bolt doesn't line up.
Re: Stupid 727 question? [Re: BossRide] #64643
05/27/08 05:08 PM
05/27/08 05:08 PM
Citrus Heights, CA
69_Swinger Offline
69_Swinger  Offline
Citrus Heights, CA
They are different. I think the bottom holes will not line up. I'm sure one of the experts will chime in.
67 Valiant /6 2-door (Father/Daughter project)
Re: Stupid 727 question? [Re: 69_Swinger] #64644
05/27/08 05:16 PM
05/27/08 05:16 PM
Andrewh Offline
Andrewh  Offline
here found this
[image]http://www.carcraft.com/newlook/crc_act/116_0302_trans/photo_06.html[/image]
Here are the two Mopar V-8 bellhousing bolt patterns used on TorqueFlite transmission. The big-block (B and RB) pattern is on the left and the small-block (A and LA) is on the right.
from
http://www.carcraft.com/newlook/crc_act/116_0302_trans/index.html
Re: Stupid 727 question? [Re: BossRide] #64645
05/27/08 06:33 PM
05/27/08 06:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If the trans was adapted to an early Hemi it's most likely a SB case which would fit a 360. The bolt holes are the easiest way to tell the difference.
Re: Stupid 727 question? [Re: John_Kunkel] #64646
05/27/08 07:24 PM
05/27/08 07:24 PM
Southaven, MS
BossRide Offline OP
BossRide  Offline OP
Southaven, MS
Awesome, thanks! It is a SB and mated with an adapter plate.
The Blue Goose
