timing chain timing #646174
03/20/10 03:35 PM
03/20/10 03:35 PM
Wichita,ks.
jst19600 Offline OP
jst19600  Offline OP
Wichita,ks.
Rebuilding a small block with solid cam and roller lifters.When your timing dots are lined up (cam sprocket dot down/crank sprocket dot up),both the #1 and #6 pistons are up.Is this TDC firing #1 or #6?
Re: timing chain timing [Re: jst19600] #646175
03/20/10 05:49 PM
03/20/10 05:49 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
#6
Re: timing chain timing [Re: supercomp] #646176
03/21/10 12:57 AM
03/21/10 12:57 AM
Firing #6 with the dots lined up to start the first cycle on #1 cylinder
