Fuel Return Line #646146
03/20/10 02:41 PM
03/20/10 02:41 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
They always specify use of the black 3 nipple vapor separator with the 440/Hemi when using a return line. What did 383's use when incorporating a return line? Is there any reason why this separator would not work on a 383?
Grandma always said I had "hands of gold"!
Re: Fuel Return Line [Re: CHRGR69] #646147
03/20/10 05:25 PM
03/20/10 05:25 PM
NJ
rth Offline
rth  Offline
NJ
383's didn't use vapor separator,just a inline filter.i believe all 383 cars came with 5/16 fuel line as 44o/hemi cars were 3/8
Re: Fuel Return Line [Re: rth] #646148
03/20/10 05:59 PM
03/20/10 05:59 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
But how would you do a return line otherwise on a 383 if I wanted one?
Re: Fuel Return Line [Re: CHRGR69] #646149
03/20/10 08:03 PM
03/20/10 08:03 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
The hemi's and 440's did not have a return line. That is a vapor return. It was there to help with vapor lock in hot weather on the RB motors. There is no need for a return line on a 383. It will serve no purpose.
Re: Fuel Return Line [Re: CHRGR69] #646150
03/20/10 08:48 PM
03/20/10 08:48 PM
Eastern North Carolina
riverman Offline
riverman  Offline
Return line is 1/4 inch. Your fuel pick up may not have the return line in it. The fuel vapor separator itself has 5/16" line size both in and out so that is not a problem.
