65 Coronet Wheel Size? #645798
03/20/10 10:01 AM
03/20/10 10:01 AM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
What is the largest wheel and what offset will fit on a 65 Coronet with stock suspension, wheel wells and rear end without any rubbing?
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: 65 Coronet Wheel Size? [Re: 65 Hemi] #645799
03/20/10 10:14 AM
03/20/10 10:14 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
You can go 15" wheels, 8" wide with a 4.5" backspace easy. 4" backspace makes it really tight on the outside. Plenty of room inside on both.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: 65 Coronet Wheel Size? [Re: 65 Hemi] #645800
03/20/10 12:02 PM
03/20/10 12:02 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I'm running an 18x10 in back with a 295/45-18. It fits fine if you get the backspacing correct.
The front 18x9 with 245/45-18 tend to rub on the fender and frame when the suspension compresses while turning. I am running a complete '69 K frame and steering arrangement so yours may be different.
- Stu Harmon
Re: 65 Coronet Wheel Size? [Re: Junky] #645801
03/20/10 05:24 PM
03/20/10 05:24 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Is ther enough room if for a 15x10 if you go with a 5.5" or 6" back spacing?
Doug
MOPAR or NO CAR!!!
Re: 65 Coronet Wheel Size? [Re: feets] #645802
03/20/10 05:26 PM
03/20/10 05:26 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
What is your back spacing and is your leafs and wheel wells stock?
Doug
MOPAR or NO CAR!!!
Re: 65 Coronet Wheel Size? [Re: 65 Hemi] #645803
03/20/10 07:45 PM
03/20/10 07:45 PM
AndyF Offline
AndyF  Offline
I have 17x10 wheels in the rear but I did move the springs.
Re: 65 Coronet Wheel Size? [Re: 65 Hemi] #645804
03/20/10 07:58 PM
03/20/10 07:58 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
I don't know. You'd just need to do the math.
Re: 65 Coronet Wheel Size? [Re: 65 Hemi] #645805
03/20/10 09:33 PM
03/20/10 09:33 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Trust me. You don't want my wheel info. Nothing is correct (or even normal) on my car with the exception of the body.
The rear end is from an unknown donor. It's a random that happened to fit.
The body is unaltered and the springs are where they belong. That's no biggie because they're even with the frame rails anyway.
You've just got to break out a coat hanger and measuring tape. Be sure to look UP when you do the rears. The side of the tires are known to rub on the outer wheelhouse a few inches above the wheel opening on these cars.
- Stu Harmon
Re: 65 Coronet Wheel Size? [Re: feets] #645806
03/20/10 09:39 PM
03/20/10 09:39 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Re: 65 Coronet Wheel Size? [Re: feets] #645807
03/20/10 10:03 PM
03/20/10 10:03 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Thanks, I have one with the leafs moved in and the wheel well split because of the rubbing. My wife let me buy this second one because it was a restored 383, AC, PS, PB car. She will probably will kill me when I pull the motor out and put my 440 in it with a 400 convertor. Lol
Doug
MOPAR or NO CAR!!!
Re: 65 Coronet Wheel Size? [Re: 65 Hemi] #645808
03/20/10 11:02 PM
03/20/10 11:02 PM
The Sunny Shuswap
dodgefarmer Offline
dodgefarmer  Offline
The Sunny Shuswap
I'm running a 295/50/15 on a ramcharger 15x8 rim. No altercations. Occasional rub.
Randy
Re: 65 Coronet Wheel Size? [Re: dodgefarmer] #645809
03/20/10 11:19 PM
03/20/10 11:19 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Is it rubbing on the out side and is it a 4" or 41/2" offset
Randy
Doug
MOPAR or NO CAR!!!
Re: 65 Coronet Wheel Size? [Re: dodgefarmer] #645810
03/21/10 09:16 AM
03/21/10 09:16 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
15x10 with 5 1/3 bs wont fit.
They will be probally 1/2 inch from the spring.My 65 has 15x10 4 1/2 bs and they will touch the outer nut my tires are 12 inch wide.Rocky
Chrysler Firepower
Re: 65 Coronet Wheel Size? [Re: 65 Hemi] #645811
03/21/10 09:26 AM
03/21/10 09:26 AM
The Sunny Shuswap
dodgefarmer Offline
dodgefarmer  Offline
The Sunny Shuswap
Yes rubs on the outside. Wheels are 4 5/16" backspace. Tires clear the spring by about 1". I also run airshocks set @ 90psi. to help eliminate the rubbing. I think that a 4.5" bs. wheel would eliminate all problems.
Randy
Re: 65 Coronet Wheel Size? [Re: 65 Hemi] #645812
03/21/10 09:35 AM
03/21/10 09:35 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
let me guess... it's rubbing the side wall on the outer wheelhouse about 2" above the opening.
Those tires are too fat for the wheel and they poof out a bit. Yes, they fit on an 8" wheel but they're much happier on a 9 or 10 incher.
- Stu Harmon
Re: 65 Coronet Wheel Size? [Re: feets] #645813
03/21/10 10:14 AM
03/21/10 10:14 AM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Thanks for all the input. I guess I will go with 15x8 with a 41/2" back spacing.
Doug
MOPAR or NO CAR!!!
Re: 65 Coronet Wheel Size? [Re: 65 Hemi] #645814
03/21/10 11:38 AM
03/21/10 11:38 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I forgot to say my 65 has a 69 rear that is a bit wider.The 4 1/2s would probally fit with the 65 rear.Rocky
Chrysler Firepower
Re: 65 Coronet Wheel Size? [Re: Junky] #645815
03/21/10 12:15 PM
03/21/10 12:15 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
And I forgot to add that my comments above is with a 275/60/15 tire. A 255/60/15 tire will be easier to run with a 4" backspace.
Re: 65 Coronet Wheel Size? [Re: Junky] #645816
03/21/10 12:22 PM
03/21/10 12:22 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Junky,
I like the way your car sits. What size are you running up front?
Doug
MOPAR or NO CAR!!!
Re: 65 Coronet Wheel Size? [Re: 65 Hemi] #645817
03/21/10 12:44 PM
03/21/10 12:44 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
In that photo I'm running 235/60/15. I've switched to 245/60/15. The 235's didn't fill the wheel well enough for me. The 245 looks much better...to me.
Also, in that photo, the rear wheels (TorqThrust D) are 8x15 with 4.5" backspace. I've switched to 8x15 with 4" backspace. Wheels now are the T70R TorqThrust. It was very tight. Had to bend the inner wheel-house wall out a bit. Took some work. Much better clearance.
