65 Coronet Wheel Size?
#645798
03/20/10 10:01 AM
03/20/10 10:01 AM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
What is the largest wheel and what offset will fit on a 65 Coronet with stock suspension, wheel wells and rear end without any rubbing?
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
Re: 65 Coronet Wheel Size?
[Re: 65 Hemi]
#645800
03/20/10 12:02 PM
03/20/10 12:02 PM
Posts: 28,137 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I'm running an 18x10 in back with a 295/45-18. It fits fine if you get the backspacing correct.
The front 18x9 with 245/45-18 tend to rub on the fender and frame when the suspension compresses while turning. I am running a complete '69 K frame and steering arrangement so yours may be different.
[Re: Junky]
#645801
03/20/10 05:24 PM
03/20/10 05:24 PM
65 Hemi
San Diego CA
Is ther enough room if for a 15x10 if you go with a 5.5" or 6" back spacing? Quote:
You can go 15" wheels, 8" wide with a 4.5" backspace easy. 4" backspace makes it really tight on the outside. Plenty of room inside on both.
Doug
[Re: feets]
#645802
03/20/10 05:26 PM
03/20/10 05:26 PM
65 Hemi
San Diego CA
What is your back spacing and is your leafs and wheel wells stock? Quote:
Doug
[Re: 65 Hemi]
#645804
03/20/10 07:58 PM
03/20/10 07:58 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
I don't know. You'd just need to do the math.
[Re: feets]
#645806
03/20/10 09:39 PM
03/20/10 09:39 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Trust me. You don't want my wheel info
[Re: dodgefarmer]
#645809
03/20/10 11:19 PM
03/20/10 11:19 PM
65 Hemi
San Diego CA
Is it rubbing on the out side and is it a 4" or 41/2" offset Quote:
I'm running a 295/50/15 on a ramcharger 15x8 rim. No altercations. Occasional rub.
Randy
Doug
[Re: dodgefarmer]
#645810
03/21/10 09:16 AM
03/21/10 09:16 AM
Posts: 21,143 Niles , Ohio
therocks
Niles , Ohio
15x10 with 5 1/3 bs wont fit. They will be probally 1/2 inch from the spring.My 65 has 15x10 4 1/2 bs and they will touch the outer nut my tires are 12 inch wide.Rocky
Chrysler Firepower
[Re: 65 Hemi]
#645812
03/21/10 09:35 AM
03/21/10 09:35 AM
feets
Senior Management
Senior Management
Irving, TX
let me guess... it's rubbing the side wall on the outer wheelhouse about 2" above the opening. Those tires are too fat for the wheel and they poof out a bit. Yes, they fit on an 8" wheel but they're much happier on a 9 or 10 incher.
[Re: 65 Hemi]
#645814
03/21/10 11:38 AM
03/21/10 11:38 AM
therocks
Niles , Ohio
I forgot to say my 65 has a 69 rear that is a bit wider.The 4 1/2s would probally fit with the 65 rear.Rocky
Chrysler Firepower
[Re: Junky]
#645815
03/21/10 12:15 PM
03/21/10 12:15 PM
Junky
Wherever I am.
And I forgot to add that my comments above is with a 275/60/15 tire. A 255/60/15 tire will be easier to run with a 4" backspace.
[Re: 65 Hemi]
#645817
03/21/10 12:44 PM
03/21/10 12:44 PM
Junky
Wherever I am.
In that photo I'm running 235/60/15. I've switched to 245/60/15. The 235's didn't fill the wheel well enough for me. The 245 looks much better...to me.
Also, in that photo, the rear wheels (TorqThrust D) are 8x15 with 4.5" backspace. I've switched to 8x15 with 4" backspace. Wheels now are the T70R TorqThrust. It was very tight. Had to bend the inner wheel-house wall out a bit. Took some work. Much better clearance.
