cracked oil pan....JB weld?
#645603
03/19/10 11:29 PM
03/19/10 11:29 PM
Posts: 4,323 NY NY
340duster340
NY NY
first off...this is the exact reason why i typically only work on my vehicles but this time i had no option as it was my daily driver and my clutch blew and i needed it fixed asap so i could drive to work.
chevy c2500 truck 4 speed should have been a no brainer, but the bozo somehow managed to crack my oil pan - presumably from how he supported it while removing the trans.
i put dye in it to confirm the leak its a tiny crack...do you think this can be JB welded?
i am going to go back tomorrow and see what they will do (if anything) but i am already bracing to fix this myself.
thanks
1966 Dart GT
...down to only 1 mopar for the first time in 15 years!
Re: cracked oil pan....JB weld?
[Re: 340duster340]
#645604
03/19/10 11:43 PM
03/19/10 11:43 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I've had good luck with a product call seal all http://www.eclecticproducts.com/sealall.htmdrain the oil and apply it in many layers usually holds on for a couple 3 years in Canadain winters to boot. Cants see why JB weld wont work but hard to get pan to stop weeping?? most hard ware stores and some parts stores.
[Re: 340duster340]
#645605
03/19/10 11:53 PM
03/19/10 11:53 PM
Posts: 12,245 Looking for a way out of Middl...
IMGTX
While not ideal. Yes. I have a car that had a bad case of road rash under the drain plug. The right fix was to remove the pan and weld it. I cleaned the pan slathered on JB Weld, used tape to hold it there, and let it set up over night. Next day I refilled it with oil. Sadly I had to do that at every oil change because it was too close to the drain plug and the JB Weld covered the plug. The things we do before we get enough tools and a shop to do it right is funny. Some will say weld the pan on the car I do not suggest that. I tried to weld the above pan on the car and the crankcase ignited and turned the open drain plug into a huge blowtorch. It was one of those nine lives moments for me when the Good Lord kept me alive and intact even though darwin tried to weed me out.
[Re: IMGTX]
#645606
03/20/10 12:05 AM
03/20/10 12:05 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
I tried it on a rusty oil pan and it held for a while... In your case, I assume you have an aluminum pan that cracked.. Drain the oil and put a quart of mineral spriits in the engine and let it seep out, to clean out the crack...then use the JB weld... Or.. at the Home Depot they sell some plumbing epoxy stuff that works even under water or under pressure.. just be sure it is clean to start with. Another thought is to solder it with an electric solder Iron..(not a gun).
[Re: 340duster340]
#645607
03/20/10 12:33 AM
03/20/10 12:33 AM
Posts: 357 Lake Elmo, MN
Evil Monkey
Lake Elmo, MN
I've used JB Weld to fix a hole in the crankcase of a 250cc Motocross bike - it would hold up for about 2 years at a time, then need to be replaced. I also used JB Weld to fix a pinhole leak in the bottom of a gas tank. Emptied the tank, cleaned the area around the hole, slathered on JB Weld, pushed a small piece of sheet aluminum (about 1" X 1") into the JB Weld so that it went up against the tank. I then waited for the JB Weld to cure, and slathered more JB Weld on top of and around the aluminum. That lasted until the car was scrapped, about 5 years later. Probably not the best way to fix a tank, but it worked!
1974 'Cuda 360/TKO
1990 Ram Van
1998 Neon
[Re: MoparJoe]
#645610
03/20/10 07:28 AM
03/20/10 07:28 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
I fixed a hole in the bottom of my kids beaters gas tank 2 years ago with it.It was dry as after it was stolen they punched a hole i it.Cleaned it real good.JB weld over a screw then a thin piece of sheet metal ad more JB weld.Its still tight as a drum.Surface has to be dry and clean.Rocky
Chrysler Firepower
[Re: therocks]
#645611
03/20/10 07:37 AM
03/20/10 07:37 AM
Posts: 4,323 NY NY
340duster340
NY NY
thanks for the advise all.
i am going to see if they will warranty the work, if not i will break out the JB weld and see what happens.
i'll post and update at eod
mike
1966 Dart GT
[Re: Chilort]
#645614
03/20/10 08:04 PM
03/20/10 08:04 PM
Posts: 4,323 NY NY
340duster340
NY NY
UPDATE
so far so good. i drained the oil, sprayed inside and out with brake clean, the sanded to bare metal and finally applied the JB weld.
i used the water-weld which says on the package it can be used for oil pans.
no leaks so far! i am curious to see how it holds up.
mike
1966 Dart GT
