440 Cast Crank - will this flywheel work? #645364
03/19/10 08:07 PM
03/19/10 08:07 PM
PA
dodgeman316 Offline OP
PA
I built an engine test stand and have my cast crank 440 mounted to it. The car won't be ready for a while and I want to be able to fire the engine and make sure it is decent before dropping into the car.
I attached a picture of a 11" flywheel that I have. Anyone know if it will work with this engine?
I am putting an automatic in the car so I'm not worried about the pilot hole in the crank, I just want to make sure the flywheel will work ok on the test stand.
Thanks in advance for any replies.
Greg
1969 Super Bee
Re: 440 Cast Crank - will this flywheel work? [Re: dodgeman316] #645365
03/19/10 08:59 PM
03/19/10 08:59 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
kinda looks like the 360 flywheel
Re: 440 Cast Crank - will this flywheel work? [Re: 500ciDuster] #645366
03/19/10 10:53 PM
03/19/10 10:53 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Should work all six bolt cranks are the same flywheel BB and SB. your balanace may be a bit off but for under 2500 who cares.
Re: 440 Cast Crank - will this flywheel work? [Re: Dodgem] #645367
03/20/10 02:03 AM
03/20/10 02:03 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Don't believe Dodgem." Who cares?" An imbalance like this will beat the hell out of your bearings. The cast crank 440 has a totally different balance factor that will be felt from a fast idle and up. It is like detonation...The damage has already started by the time you notice it. To suggest to just go ahead and use it is stupid and irresponsible. If you had to get your rig together to take a dying relative to get an operation and you didn't have another car or a horse.... then maybe it might make sense to use it Factory engines are usually balanced to a sloppy limit of 6-7 grams. A professional can get it to less than one. The 360 has a 19.79 weight for the offset. Whats your engine worth?
Re: 440 Cast Crank - will this flywheel work? [Re: Kern Dog] #645368
03/20/10 02:12 AM
03/20/10 02:12 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Thats a 360 wheel. Heres a 440 cast wheel.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 440 Cast Crank - will this flywheel work? [Re: moparmarks] #645369
03/20/10 10:45 AM
03/20/10 10:45 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Sorry I got confused by adds like this
McLeod Steel Flywheels
Flywheel, Steel, 130-Tooth, 33 lbs., Internal Engine Balance, Big/ Small Block.
Lightweight alloy flywheels can offer substantial benefits for certain situations, but sometimes they're just not your cup of tea. Maybe you're on a budget, maybe you're running a heavy drag car, or maybe you just don't need those benefits. In those cases, McLeod has the answer. Their steel flywheels deliver all of the strength and reliability you need, at a substantially lower price. They're neutrally balanced, but are drilled to accept balance weights for use on externally balanced engines. They're available for a wide variety of large and small engines.
$354.95
MCL464102
I still say for break in on an engine stand a little vibration at lower rpms no load would not bother me but that is me!
Re: 440 Cast Crank - will this flywheel work? [Re: Dodgem] #645370
03/20/10 01:44 PM
03/20/10 01:44 PM
PA
PA
Thanks for the replies.
Anyone have a used cast crank flywheel they want to get rid of reasonably cheap?
If I can get one cheap enough I'll probably just pick one up and then I don't have to worry about it.
Re: 440 Cast Crank - will this flywheel work? [Re: dodgeman316] #645371
03/20/10 07:35 PM
03/20/10 07:35 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
A big block cast crank flywheel is going to be pretty hard to find. Since it is only going to be temporary then just put a B&M 440 cast crank flex plate between the crank and a neutral balance flywheel. If starter engagement is a problem then put washers between the bellhousing and block that are the same thickness as the flexplate.
Re: 440 Cast Crank - will this flywheel work? [Re: 446acuda] #645372
03/20/10 08:20 PM
03/20/10 08:20 PM
PA
PA
Any thoughts on using one of these??
Looks like it is a weighted plate for using a neutral balance flywheel.
http://www.kmjent.com/cart/product.php?productid=2077&cat=7109852&page=1
Re: 440 Cast Crank - will this flywheel work? [Re: dodgeman316] #645373
03/20/10 08:30 PM
03/20/10 08:30 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
what engine is that for? It doesn't say so in the ad. 440 cast crank and 440 cast crank require 19.79 in.-oz. balance weight.
Re: 440 Cast Crank - will this flywheel work? [Re: 446acuda] #645374
03/21/10 12:08 AM
03/21/10 12:08 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Measure the size of the holes.
31/32 will be a 440 crank. Here's the diagram for drilling the balance holes
A 360 uses 1 13/64 drill.
Re: 440 Cast Crank - will this flywheel work? [Re: RobX4406] #645375
03/21/10 10:34 AM
03/21/10 10:34 AM
PA
PA
RobX - thanks for the diagram. Based on the measurements the flywheel I have is definitely for a 360.
