904 Low Gear Set Transmission Question- #645318
03/19/10 08:04 PM
03/19/10 08:04 PM
Los Angeles
Hazwoy Offline OP
Hazwoy  Offline OP
Los Angeles
I love the new low gear set in my new 904 street/strip transmission. 1972 Charger, 300 + hp daily driver. Really like the ratio spread and would recommend to everybody whether heavy car or light car if daily driver. However I do notice a bit of gear whine whenever in first gear. Similar to a lot of transmissions when you put in reverse. Not enough whine to annoy me but enough to know its there.
Anybody else with low gear set notice same situation?
Re: 904 Low Gear Set Transmission Question- [Re: Hazwoy] #645319
03/19/10 08:20 PM
03/19/10 08:20 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
I never noticed a whine when I had mine in street car, but I can assure you when you throw 600+ hp at it in a car that weighs 2400 lbs you will soon realize there is no need for that gear set......unless you like 4 1/2 wheelstands and unpredicatable launches. DAMHIK
Re: 904 Low Gear Set Transmission Question- [Re: Hazwoy] #645320
03/19/10 08:21 PM
03/19/10 08:21 PM
the oe one in my former '83 cordoba (318/904) daily driver was quiet or I would have remembered it
Re: 904 Low Gear Set Transmission Question- [Re: RapidRobert] #645321
03/19/10 08:40 PM
03/19/10 08:40 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
The low-gear 999 that I put in my Fury whines a little bit in first gear. I can hear it over the 2 1/2 duals when taking off easy in traffic
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
