cruzor 01 wheels by wheel vintiques #644773
03/19/10 04:32 AM
03/19/10 04:32 AM
United states wisconsin
bigblockbryan Offline OP
bought some last week and looks like i can use factory lug nuts on these am i wrong let me now thanks
Re: cruzor 01 wheels by wheel vintiques [Re: bigblockbryan] #644774
03/19/10 11:16 AM
03/19/10 11:16 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Do they have a standard tapered seat ? Most of the aftermarket wheels seem to use that style and can use the normal acorn seat lug nut. Unless they are designed for a washered mag nut....I'm not familiar with that wheel, but just a simple look at the lug nut mounting surface on the wheel should tell you for aftermarket wheels. (99% of the time anyways)
Re: cruzor 01 wheels by wheel vintiques [Re: OzHemi] #644775
03/19/10 11:52 AM
03/19/10 11:52 AM
BDW Offline
BDW  Offline
Check the specs on the website or Summit, it will indicate the type.
Here's an example:
Wheel Diameter 17 in.
Wheel Width (in) 8.00 in.
Backspacing (in) 4.500 in.
Offset (mm) 0.00mm
Wheel Material Aluminum
Wheel Finish Black/Silver
Wheel Construction 1-piece
Beadlock Included No
Beadlock Functional No
Lug Nut Seat Style Conical seat - 60 degree
Hub Centric No
Center Cap Included Yes
Valve Stems Included No
Re: cruzor 01 wheels by wheel vintiques [Re: BDW] #644776
03/19/10 05:18 PM
03/19/10 05:18 PM
Buffalo, MN
hydro Offline
super street
hydro  Offline
super street
Buffalo, MN
They use acorn nuts with tapered seat, not the special "mag nuts"
See below........
Re: cruzor 01 wheels by wheel vintiques [Re: hydro] #644777
03/19/10 06:20 PM
03/19/10 06:20 PM
okay thanks your car looks pretty sweet i post one of the fury when i get them on
